Rotor help...
Old Aug 30, 2002 | 08:57 PM
Auraraptor's Avatar
Default Rotor help...
Just wonderng, what is the oem rotor size on the fronts and rears (5th gen)? Is there a drum brake (for the hand brake) in the rears as well? I was wondreing if you could put 'old' fronts in the rear if you upgrade the fronts...
Old Aug 30, 2002 | 09:36 PM
LordVtec's Avatar
Default Re: Rotor help... (Auraraptor)
The Front and Rear rotor sizes on the 5th gen are different... i recently bought crossed drilled and slotted rotors for my 5th gen, one pair is bigger than the other.. (not sure but i dont think it would work to use the front in the rear..)
Old Aug 31, 2002 | 01:43 PM
cybercrx00
Guest
Posts: n/a
Default Re: Rotor help... (LordVtec)
most likely you would need a different caliper in the rear for the vented front rotor which is like 2.5 times wider than the non-vented rear.
Old Aug 31, 2002 | 01:55 PM
Auraraptor's Avatar
Default Re: Rotor help... (cybercrx00)
I intend on using the complete front assembly, ie the caliper and the rotor from the front and place them in the back...if its possible, which is my question, along with the demensions of the rotor I think its like 11.1 in/282 mm I think...but am not sure, is that the right demensions?
Dekorum
Sep 14, 2018 08:48 AM
liukangus
Mar 17, 2009 01:36 PM
Unidentified
Sep 4, 2006 06:53 PM
