NEED A MECHANIC TROUBLESHOOTING
in need of a mechanic my car dont want to start change the fuel pump,main relay check spark and it show bright white and check all the fuse but still dont start but it cranks like it wants to turn over but still nothing so IM IN NEED OF A MECHANIC THAT IS WILLING TO SHOW UP TO MY HOUSE TO CHECK IT OUT THANKS FOR EVERYBODY SUPPORT
if you have spark and you have fuel, then go to this.
do a leakdown test on the motor, you could have a warped head or bent valves and doesnt not want to build compression to start.
if tests come out ok, check your timing. bring up piston 1 (which is all the way to the right of the motor if ur standing infront of the car) u can either stick a screw driver in the spark plug hole in cyl 1 or just look at the crank pulley, there is 2 small lines on the crank pulley, u will see that there is also a small line on the plastic cover that covers the oil pump. lines those two up and look at your cam gears, there are arrows on the gears they both should point up and there are also small dots on the cam gears on the side, they should align with the head. check that out n get back to me. (also) make sure everything is intact nicely in ur dizzy, incase if its ever been rebuilt. loose wires or such will get in the way of letting the cylinder fire occourdinly and will cause a no start condition but WILL give spark.
2000 honda civic 4 door 2000 gsr swap 00 honda civic si engine harness obd1 jumperharess to the ecu with a p30 chipped ecu rannn before just stoppp running like 4 days ago ran this motor for like almost 8 months before this happen
EGed up from the seat up
Jul 23, 2009 04:47 PM
u2civic1
Feb 6, 2003 10:43 PM
merlyn
Dec 15, 2002 10:39 AM
