f22b2 Shaking [Oil in spark plug]
Old Nov 4, 2009 | 03:47 PM
Zendos's Avatar
Default f22b2 Shaking [Oil in spark plug]
Well i was just driving and i noticed that my car was shaking, i was near a shop so i just went and got my oil changed, problem still was there. So i went home and did a few tests, and i decieded to check to spark plugs, and this is what i come to find out.
One Spark Plug Is Dry and has no oil.
You can see how it looks compared to the other ones, but im not sure if this would be a problem. Can someone help me. Could it be the Valve Cover Gasket? If so, how do you fix? how much would the parts cost
Old Nov 4, 2009 | 04:04 PM
nus_dogg's Avatar
Default Re: f22b2 Shaking [Oil in spark plug]
No, its not the valve cover gasket. Its your lower spark plug o-ring. You'll have to pull the rocker arms off and be able to remove and install the new o-rings. Minus well do all four while everything is apart.
qhiggy
10
Mar 3, 2015 08:49 PM
koulninja
12
Aug 1, 2011 08:51 PM
foxfai
Mar 31, 2009 08:03 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
matryx
Dec 15, 2007 01:18 PM
