d16z6 problem
ok i just bought hatch from some dude and it is wired to obd1 and check engine light is on and i cant figure out why so im convert it pack to obd0 does the 90 honda civic si manifold fit the z6?
the light stays on because you have a sensor picking up a problem.
Look under your glove box near the ECU for a blue connector that isn't connected to anything.
Put a jumper in that connector and turn your ignition to ON.
Count the blinks on the CEL... go fix the problem.
Phearable has a nice write-up that shows the connector
http://www.phearable.net/tech/mil/readcodes.html
serious
Mar 29, 2003 07:44 PM
