91 crx si b16a bogging code 6,9,10
Old Nov 4, 2009 | 09:44 AM
andrew1315's Avatar
Icon2 91 crx si b16a bogging code 6,9,10
hey i got a 91 crx with jdm b16a obd0 with pw0 ecu it's throwing code 6 which i know is my coolant temp sensor and 9 which is my cyp sensor and code 10 which is my iat sensor. changed the cts and iat but the car still bogs sometimes but not all the time i know you cant change the cyp sensor so should i just change the dizzy? anyone have any other ideas? it seems like i have no power know and its throwing the cyp dizzy code still.
Thanks,
Andrew
Old Nov 4, 2009 | 10:16 AM
Rignasty's Avatar
Default Re: 91 crx si b16a bogging code 6,9,10
having any problems with start up?
Old Nov 4, 2009 | 10:21 AM
andrew1315's Avatar
Yup it takes a few tries. But it fires up with live so i think its the dizzy 4 sure I'm gonna replace that and see if it helps its just hard do find a dizzy for b16 obd1
Old Nov 5, 2009 | 07:26 AM
intevic94's Avatar
i have the same issue. i trying a code 5 and code 9. when you can the dizzy did it fix code 9. how to you fix the map sensor. should you just can it?
Old Nov 6, 2009 | 06:02 AM
andrew1315's Avatar
Icon3 Re: 91 crx si b16a bogging code 6,9,10
i changed the dizzy and still same problem code 9 then noticed the engine timing is off by like 3 teeth on the crankshaft pulley resetting the timing now hopefully this will stop everything i was told the timing being off can throw the cyp sensor also.
Old Nov 6, 2009 | 07:36 AM
andrew1315's Avatar
timing set still throwing code 6,9,10 but all the power is back and no more bogging? any ideas anyone?
Old Nov 6, 2009 | 07:37 AM
andrew1315's Avatar
Icon2 Re: 91 crx si b16a bogging code 6,9,10
what do you mean by can it?
Crackback
Mar 12, 2008 06:22 PM
EF8 JUNKIE9
Aug 7, 2005 09:54 PM
aHOLE
Feb 20, 2003 04:50 PM
mrduque
Jun 30, 2002 12:09 PM
