How can i replace the turn signal switch?
my turn signal switch broke from my 94 accord and i need to replace it. i already have the part, its the turn signal and the wiper switch combined. i need instructions on how to replace it with pic preferably plz, or where i can get these instructions. i already tried searching for it through the forums and google but no luck.
thanks
thanks
There is like 4 screws or so.. Then it slides up and over, or down and over.. There will be some wires with regular push clips and its out.. Real easy fix.. Like 5 min
EDIT:: I can take pics later if I still need to, buts its self-explainitory if you just look @ it..
ok i ran into a problem, from the pic redbull-1 sent i took off everything in step 1 and 2 but on step 3 im stuck...my turn signal piece is together with the wiper switch so i have to take both of them off. thats how the new piece i have is. looks like im going to have to take off the steering wheel. any ideas how to take that off? the part i need to replace together is like this pic....
looks like the pic didnt work, heres the url:
http://media.photobucket.com/image/9...s/RG_11473.jpg[IMG]
http://media.photobucket.com/image/94%20honda%20accord%20combination%20switch/duckiller01/Roberts%20Parts/RG_11473.jpg[/IMG]
Can you take a picture and post your steering wheel area, so I can see if they are even the same part for your car? The part you show may be for a different year.
The replacement part you have doesn't look the same as the ones for a 5th gen Accord, as listed on Ebay.
I no longer own a 5th gen Accord, so I can't go out to the garage and see.
yup looks exactly the same as the one i bought. i uploaded pics of my stearing wheel and the part i bought. the part i bought i got it n a junk yard from a 94 accord (same year n model.) look at my pics cuz i dont know how to upload them here without the url.
that piece doesnt come apart when u take off the screws, its all a single piece except for the part where the wires with clips connect to. so does that mean i have to take off the steering wheel? cuz the guy that took off the part i bought removed the steering wheel to get it out. i just dont know how.
The url link you posted, which is this picture doesn't look like the other ones from ebay.
What are the urls to the pictures of your steering wheel? (To attach pics, you can also attach the files, which are part of the 'Additional Options'.
Also, does your car have an air bag in the steering wheel?
Okay, that one is the same. It should just pull out after you remove the two screws.
I wouldn't remove the whole steering wheel just to replace the switch. Try wiggling the switch part at the base a bit to see if it will come out.
ok got it...it came off thanks...now to fix my guages...it was easy, i guess i was just being narrow minded...thanks again.
hey redbull_1 i think u should do a how to: on this since its not on the site...u really helped.
Great! Glad you replaced it. If you would have taken off the steering wheel, you would have made alot of work for yourself; so, I'm glad it didn't come to that. I would of helped you with that; but, didn't want you to go that route.
yup i know what u mean...that would have been a pain in the butt...and taking the risk of the airbag deploying on me...well now that i have half of the dash out im going to fix a couple little more things with my gauges...no biggie though.
thanks again
thanks again
I have Honda accord 2003 and had same problem with my turn signal. Right side don't work at all.No lights front and back.After reading this post and replace at turn signal
flasher and works fine now.Just let you know ,dealer told me that if turn signal works on oneside it not flasher problem.well,it is not true .they want you to come in and spend few hundred bucks on diagnostic.Well ,I 've only spend $20 thanks to you all. good work
