need help with wire harness connectors and H22 swap
hello to anyone that reads this. my timing belt snapped 4 weeks ago and decided to install the h22a that i bought in june. i noticed as i was yanking the old engine out that someone cut the connectors from the engine wires on the h22. now im pretty good with these types of things(wiring) but i dont have a clue to which wires go to which connectors. pleassssssssssssse help. i miss driving.
Almost everything is cut off when you order a motor (wiring harness, hoses, etc) because you're not going ot use them anyways. You use your accord's wiring harness, so that it'll plug right up to your subharness, then plug it up to all the sensors on your H22 accordingly. Some of them you'll have to extend the wires to each, some of them you'll have to switch plugs, and you'll have to use two or four plugs from your H22 harness, plug them to your H22, and run those wires with your F22 harness. I'm assuming you're using some sort of swap guide, it should explain it in there.
