CEL p1457
Old Nov 3, 2009 | 07:38 PM
slammed em1's Avatar
Default CEL p1457
wats up guys i finally got my cel checked and is says i got check engine light P1457.....i looked it up and its Emission Control System Leak Detected(Control Canister System)...i try to find a write up on it but cant...is this an easy fix?? i wanan do it myself but idk what this is or where i ahve to look or where i can check it.....byc ar idles rough soo im guessing its this....can anyone help??
Old Nov 4, 2009 | 10:05 AM
Default Re: CEL p1457
bump nobody knows??
Old Nov 4, 2009 | 10:11 AM
Simkin314's Avatar
Sounds to me like your referring to the charcoal canister contraption that vents gas fumes into your intake manifold. If it is what I'm thinking of, it is fairly easy to remove. What car do you have?
Old Nov 4, 2009 | 10:12 AM
a 1997 auto honda accord lx
Old Nov 4, 2009 | 10:39 AM
Simkin314's Avatar
Allright, that helps a bit. You should have something like this (i'm not certain what year accord this photo came from)
Basically, the charcoal setup stores excess fuel vapor from your gas tank due to expansive pressure buildup within the tank. When the pressure reaches a point, a solenoid (likely as mentioned in the picture 'two way valve') opens allowing the pressure to drain into the 'evap control canister.' This charge is stored inside the canister until there is appropriate engine vacuum. At that point, the ecu actuates another solenoid ('evap purge control...') thereby feeding the fuel vapor into your intake manifold via a port on the top of your throttle.
Your cel suggests that it is detecting a leak somewhere in that setup. So trace along the specific vacuum lines associated with the evap system and see what you can find...
Please note: I have never worked on, nor owned an Accord so take this information at your own risk.
Old Nov 4, 2009 | 08:36 PM
i think have a blown headgasket...(i wrote think because before my car used to smoke and struggle to turn on and usually blowing out alot of white smoke, but right now its not doing anything like that)....
you think this might be the problem??
Old Nov 5, 2009 | 07:01 AM
Simkin314's Avatar
Originally Posted by slammed em1
i(i wrote think because before my car used to smoke and struggle to turn on and usually blowing out alot of white smoke, but right now its not doing anything like that)....
Hmm, white smoke can be construed as coolant burning inside your combustion chamber. On the other hand, I can't think of any reason why an emission control system (cel) would have anything to do with that.
A lot of people would probably tell you to do a leakdown test and check your compression... Check your oil for impurities (such as coolant).
Old Nov 5, 2009 | 07:20 AM
1grex's Avatar
For your code, I'd try a new gas cap first
KingJeremy2315
Dec 1, 2015 12:39 PM
Ryan2005accord
May 7, 2015 05:15 AM
Brian Rose
Dec 27, 2014 02:14 PM
titosek4
Aug 31, 2009 09:02 AM
RiceD16
Dec 24, 2002 09:10 AM
