D16Z6 Swap help
Old Nov 3, 2009 | 06:55 PM
thegoatc's Avatar
Default D16Z6 Swap help
Hi I have a 88 ef that i did a d16z6 swap on. The swap consisted of a y8 mani, obd1 dizzy and obd2 injectors. The car was dpfi before i started. I used this wiring diagram to convert the injectors and dizzy over. Then i used a friends prebuilt obd0 to obd1 harness (i wont say what brand name but it works great in his car) to convert crom obd1 to obd2. Now i have the car started and it runs great but... The engine light comes on. This is not like a normal engine light it turns on for about a 5 count then off for one count. It always does this and when the light cycles the car surges making it difficult to drive in town. I have double and tripple checked my harness and the only differnce between mine and my friends is i have my own wires for the injectors instead of them going throught the original harness.
Hoping someone else has had this problem and is willing to shed some light on the subject.
Eric
Old Nov 3, 2009 | 07:04 PM
BiG ChOr!Zo's Avatar
Default Re: D16Z6 Swap help
87 civic tech questions belong in the forum link below...!!!
https://honda-tech.com/forums/classic-hondas-106/
Old Nov 4, 2009 | 08:14 AM
thegoatc's Avatar
Sorry it is a late 87 so it is still an ef 88 is the actual body style.
Eric
Old Nov 4, 2009 | 01:12 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Originally Posted by thegoatc
y8 mani, obd1 dizzy and obd2 injectors. obd0 to obd1 harness to convert crom obd1 to obd2.
Wait, you are OBD-1 or OBD-2 now (which ECU are you running)? Also, when you did the injector wiring where and what did you hook each one up to?
Old Nov 4, 2009 | 01:54 PM
thegoatc's Avatar
Now i am obd1 and i am running a p28 ecu and I am using the injector outputs on the ecu with a 12+ source going to the other side of the injectors.
eric
Old Nov 4, 2009 | 02:18 PM
4drEF's Avatar
Keyboard Humorist
Just a guess... Map sensor?
And it seems that you have permanently jumped your ECU into diagnostic mode somehow.
OBD1 puts the codes out at the check engine light, but ONLY after you short two wires together... seems like yours might be shorted.
Old Nov 5, 2009 | 01:09 AM
thegoatc's Avatar
no these two wires are not jumped togather i can jump them togather and from what i can tell it is sending a code 10 but if i check the resistance for the intake temp sensor it is in spec so really don't know what to do at this point.
Eric
Old Nov 5, 2009 | 04:09 AM
gnar kill's Avatar
I thought this as well but it blinks in 5 second intervals and changes when he jumps it to get the code. That is why he is thinking a code 10 IAT. It is not a normal CEL light I am confused as to why it is only blinking in 5 second intervals when it is not jumped. Does anyone have any input?
-Casey
Old Nov 5, 2009 | 09:50 AM
gnar kill's Avatar
bump I am curious about this as well....I have read else where about a "no code" cell that acts similar to this and was solved by replacing the main relay. But the main relay was replaced with a brand new one and the ECU runs my obd1 crx z6 just fine with no codes.
Old Nov 7, 2009 | 01:22 PM
gnar kill's Avatar
TTT
Old Nov 10, 2009 | 06:11 PM
thegoatc's Avatar
to the top to see if any one can help
Eric
Old Nov 16, 2009 | 03:01 AM
thegoatc's Avatar
desprate try ti see if anyone has any input
ww3slayer
Aug 23, 2010 04:28 PM
97civicgc
19
Jan 20, 2009 10:18 PM
teal_dx
Mar 10, 2008 08:09 AM
Harlowe
20
Dec 2, 2007 10:17 PM
JDMvirginNC
Mar 14, 2006 07:02 AM
