Clutch Issue - 95 Integra LS
Old Nov 3, 2009 | 05:54 PM
Smoked95Teg's Avatar
Default Clutch Issue - 95 Integra LS
OK, guys Im new here and I really need your help. I installed a F1 Stage 1 racing clutch in my 95 Integra LS today. I think I may have put the clutch disk in backwards. I put the raised side of the disk into the pressure plate or facing the tranny. If I push the clutch pedal all the way to the floor when the car is in gear you hear this rubbing/grinding noise. If you push the clutch pedal to the floor you cant put the car in gear but if you push the pedal half way you can. I think the fingers on the pressure plate are getting pushed so far that they are rubbing on the clutch disk. Is that possible? I could have sworn I put everything together right. Any help would be greatly appreciated. Thanks.
jdmcivic2fast
Apr 3, 2013 08:21 PM
lancerkid06
Dec 27, 2009 05:47 PM
tripledubz
Jan 26, 2008 07:05 AM
95frostwhite_integra
May 31, 2007 10:10 PM
3rdGteg
Nov 5, 2002 05:02 PM
