accord 98 over heats HELP Needed!!
Old Nov 3, 2009 | 07:57 AM
hiddenvictory's Avatar
New User
Default accord 98 over heats HELP Needed!!
Hi, i have accord 98 4 cyd.. and it over heats sometimes and when i give more gas (race) while driving or standing.. the temp guage comes down slowly then it moves up slowly sometimes.. Pls explain what this could be??? its been happeing quite a few times now.. i changed the spark plugs..should i change the wires will that make any diff..???? Thanks
Old Nov 3, 2009 | 08:03 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: accord 98 over heats HELP Needed!!
Do the fans come on?
Have you checked your coolant levels?
Old Nov 3, 2009 | 08:06 AM
P_Adams's Avatar
Either your coolant system is low on coolant (check it with the engine cold via the radiator filler cap) or
You've developed some air which has become trapped in the coolant system or
One (or both) of your radiator mounted cooling fans have ceased working.
You'll have to do the "grunt' work on this.....
i applaud your wish to dive into this stuff, but spark plugs and wires aren't going to address this...
P
Old Nov 3, 2009 | 09:03 AM
New User
The coolant level goes down once in every month maybe a leak in radition you think would cause to heat up?? The fan works fine.. how can i take the air out if its trapped in the coolant system? i really apprecaite your help.. Thanks
Old Nov 3, 2009 | 09:07 AM
There should be 2 fans, are they both working? With the heat on full blast both should come on
Old Nov 3, 2009 | 09:15 AM
New User
yes both the fans comes on with the heat on all the way
Old Nov 3, 2009 | 09:29 AM
Sounds like coolant issues then as P suggested
Are you seeing any leaks? Around hoses, bottom of radiator, or water pump area?
Old Nov 3, 2009 | 12:31 PM
CarsAddict's Avatar
are your fans properly connected. that could be a problem.
Rumrunner
Mar 15, 2018 01:51 PM
Emerson_Hill
Sep 15, 2014 11:26 AM
BnnyBlnco
Apr 17, 2012 10:37 PM
nc2wheels
Dec 4, 2011 11:30 PM
jnb0111
Jun 8, 2011 01:45 PM
