Daytime Running Lights (DRL) and Highbeams
Hey back again, my car is due for inspection trying to figure out why I have no DRLs or a right high beam. I checked the fuses\bulbs there all good, I changed the DRL relay still nothing. The two regular beams work great and the left high beam. Just wondering about maybe a ground and where that is located if anyone knows? Also where is the DRL relay located, is that under the steering wheel area also? Not 100% sure if i had the right relay when i checked, but the wire fit into it no problem. I tried searching on here and google and the DRL relay seemed to fix most problems like I am having. maybe I unplugged the wrong relay?
Thanks,
Thanks,
there is a box underneath the wheel, on the right side, up in under the dash, it should have some sort on bluish color plug on it
if that dont work, try taking off yer gauge cluster, poppin or removing the drl bulb, and then parallel wire your high beams together, it works...
Froggy11
Jun 8, 2011 04:30 AM
LanayAllDay
Nov 3, 2010 10:13 AM
