90 hf with d16a6 runs for 2 sec and dies starts after and keeps doing the same
Old Nov 2, 2009 | 10:47 PM
JDM-JAMES's Avatar
Default 90 hf with d16a6 runs for 2 sec and dies starts after and keeps doing the same
hey i got a crx hf with a d16a6 motor with d16z6 head the car will fire up no problem but only stays running for 2-5 sec and dies recranking it will restart it for another 2-5 sec no codes on ecu i have tried pm6 pm8 and pr4 ecu all the same problem
but if i pull the tps and map sensor plugs off it will fire up and run like a wrx idle rev all that forever
when i put them back on and restart it will run super smooth but only for the 2-5 sec
the car has gas
oh and when the tps and map or hooked up i can pump the pedal to keep it running a little it runs really rough
Old Nov 2, 2009 | 10:49 PM
90RENOsedan's Avatar
Default Re: 90 hf with d16a6 runs for 2 sec and dies starts after and keeps doing the same
with the z6 head, it seems like you'd want to try a p28.
Old Nov 2, 2009 | 10:56 PM
JDM-JAMES's Avatar
it should run off the pm6 ecu it doesn't need to hit vtec or anything just idle
Old Nov 2, 2009 | 11:00 PM
how is your fuel pressure?
and a pm6 is obd-0, while a p28 is obd-1
which is your car? converted obd-1 or still obd-0?
Old Nov 2, 2009 | 11:04 PM
JDM-JAMES's Avatar
the car is still obd0 i will be using a chipped pr4 obd0 with vtec hooked up to the auto pinout on turboedit
fuel presshure is fine 50 psi
Old Nov 2, 2009 | 11:07 PM
i'm not sure what it could be.
i'm sure if this stays at the top, someone will have an answer for you tomorrow.
sorry man.
good luck.
Old Nov 3, 2009 | 06:14 AM
jlicrx's Avatar
do you have OBD0 distributor on it?
Old Nov 3, 2009 | 07:39 AM
4drEF's Avatar
Keyboard Humorist
Was this car ever running before the problem?
Old Nov 3, 2009 | 09:38 AM
JDM-JAMES's Avatar
yes the a6 obd0
JDM-JAMES's Avatar
yes the hf swap was running
Old Nov 7, 2009 | 10:51 PM
JDM-JAMES's Avatar
bumppp
scottytee
Aug 22, 2012 08:12 PM
GABOCRX
Engine Management and Tuning
Jun 12, 2009 08:48 AM
thevtecnician
54
Jul 24, 2006 11:16 PM
W O T
May 14, 2006 04:44 PM
Rikter
Mar 19, 2006 08:46 PM
