SRS Light!?
the srs light mean the your restraint system has been tampered. a short or somehitng dumb, what you can do is try to reset your ecu by removing the fuse in the bottom right of the fuse box in the car or un doing the battery cables. If that dosent work the sensor for the oassenger side is on the passenger side of the car behind the ashtray and **** in a (92-95 civic), that dosent work try checking the fuse under the hood or in the fuse section. good luck
Cdeese910
Oct 25, 2012 07:56 AM
