Noobie from OH-IO build thread...
Old Nov 2, 2009 | 04:27 PM
wvridgerunner's Avatar
Default Noobie from OH-IO build thread...
Been on here for a little bit but finally got around to posting my ride.
CAR: 1992 Honda Civic VX 150,XXX on Clean Title Chassis
Motor: 1995 Acura Integra GSR B18C1 80,XXX Miles and 500 since rebuild
Current Dyno Tune on Pump Gas is at 10PSI Making roughly 265WHP 200WTQ
Engine Management
Hondata S100 Tuned by Corey at Slowmotion
Engine Bay
B18C1 Fully Built By Slowmotion
Block was Cleaned, Bored, Honed, and Boiled
Crankshaft Cleaned, Polished, and Camphered
CP Pistons
Manley H-Rods
Supertech Blockguard
Cosmetic Headgasket
ARP Headstuds
New OEM Water pump, Oil pump, and Timing Belt
ACL Bearings
GSR Head complete multi-angle valve job and Head cleanup
JRSC Supercharger, JRSC 10psi Pulley, JRSC Intake Manifold, JRSC Underdrive Pulleys
Hondata Intake Gasket
RC 450cc Injectors
Golden Eagle Fuel Rail
SlowMotion Spark Plug Cover
MSD Performance Cap, MSD Digital SCI + Ignition, MSD SS Blaster Coil
ACT HDG6 Clutch Kit
ACT Flywheel
AEM Cold Air Intake
B&M Fuel Pressure Regulator
Exterior
OEM VTEC Decals
Ceramic 4-1 Header
3” Custom SlowMotion Exhaust System, 3” High Flow Catalytic, 3” Vibrant Muffler, 3” Flex Section
OE Fog Lights
Interior
JRSC Fuel Pump
USDM Acura GSR Front and Rear Seats
Pioneer CD Player (Touch Screen)
AutoMeter Pro Comp Gauge Air Fuel Ratio
AutoMeter Pro Comp Gauge Boost
MSD Shift Light
Suspension, Brakes, and Wheels
OEM Front Strut Bar
Skunk 2 Rear Strut Bar
Eibach Coilovers
OEM Calipers
Stainless Steel Brake Lines
Power Stop Cross Drilled and Slotted Rotors
Hawk HPS Brake Pads
Future plans include moving from the SC to a turbo setup. (Need more boost!)
Runs great for my DD. All comments are welcome, thanks.
Old Nov 2, 2009 | 04:31 PM
Default Re: Noobie for OH-IO....
Some more Pics. (Not to greatest!)....
Old Nov 2, 2009 | 06:36 PM
fastrxu's Avatar
Default Re: Noobie from OH-IO....
Fckn sick
Keep us posted when u turbo it
Old Nov 2, 2009 | 06:52 PM
acake em1's Avatar
Colonel Cake Mix
very nice man.. i cant wait to see the snail
Old Nov 2, 2009 | 06:53 PM
Vindicator9000's Avatar
318 Curves, 11 miles
OH-HI-OH-HI-OH! ROUND ON THE END HIGH IN THE MIDDLE!
Car's just about as perfect as it gets for me. Kudos. It's cool to see someone doing something a little different than the usual setups.
Welcome aboard.
Old Nov 2, 2009 | 07:03 PM
DOHCtorEK's Avatar
sick *** build. keep it up.
Old Nov 2, 2009 | 07:30 PM
93egSLEEPER's Avatar
cant wait to see the boosted numbers. you will add another 50 or so whp to it with the same boost. you can easily push 400whp out of the build with a good tune and turbo. GL man
Old Nov 2, 2009 | 09:22 PM
HarosGSRek's Avatar
clean *** hatch...
beautiful
Old Nov 2, 2009 | 10:30 PM
fastrxu's Avatar
What times do u run if i can ask?
Do u drag race?
Autox?
Or just spirited driving
Old Nov 3, 2009 | 02:13 PM
Thanks to all for the feedback.
As for times, I have not had it to the track yet. Its my DD. It will see some tack time next year for sure.
Keep the feedback coming!
Old Nov 3, 2009 | 02:20 PM
Thanks.
Old Nov 5, 2009 | 12:55 PM
Default Re: Noobie from OH-IO build thread...
Bump it!
Old Nov 7, 2009 | 07:20 PM
95Sol99civic's Avatar
Nice O-hi-O ride glad to see I'm not the only nice rides around. Slowmotion kicks ***!
Old Nov 8, 2009 | 03:52 PM
Thanks!
Old Nov 8, 2009 | 04:24 PM
D Griff's Avatar
nice hatch man, sweet motor and I love the blue color!
I'm not really feeling your interior, but to each his own
Old Nov 8, 2009 | 04:35 PM
josiah965's Avatar
thats niceee how much money have u put into it?
Old Nov 8, 2009 | 06:06 PM
ChadB's Avatar
check out
www.ohiohondas.com
Old Nov 9, 2009 | 01:07 PM
Thanks!
I dig the OE interior, pics don't do it justice, its really clean.
Old Nov 9, 2009 | 01:08 PM
I have put a good bit of money in it over time. Motor Build alone was around 4k. I was able to pick up the whole car before the build about 2 years ago for only 2k. Thanks.
Old Nov 15, 2009 | 02:48 PM
Bump!
Old Nov 15, 2009 | 03:11 PM
WeakSauce92's Avatar
nice build!! Did you serve a tour in Iraq?
Old Nov 15, 2009 | 03:29 PM
3M1mugen's Avatar
bump!!! productive project u got,i likes
Old Nov 15, 2009 | 03:35 PM
iiPancho's Avatar
Bump for OHIO
Old Nov 15, 2009 | 04:16 PM
D Griff's Avatar
I like the original interior also, but is that white/silver around your head unit/clinate control stock, it looks strange to me... not to criticize, you're car is awesome
Old Nov 15, 2009 | 08:36 PM
backyard_concepts's Avatar
nice
