sohc zc non v-tec
Old Nov 2, 2009 | 03:39 PM
elchapin's Avatar
Default sohc zc non v-tec
I have a sohc zc non v-tec motor with a blown head gasket that I want to fix what head gasket is the correct one to get.
thanks
Old Nov 2, 2009 | 04:45 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: sohc zc non v-tec
Any 88-00 D15 or D16 head gasket... It just depends if you want a graphite one or a metal one. Once you decide that, then we can be of better service to you.
Old Nov 2, 2009 | 05:45 PM
elchapin's Avatar
Thank you just wanted to make sure
Old Nov 2, 2009 | 08:42 PM
949's Avatar
949
just curious whats the advantage / disadvantage of the graphite one or a metal one?
Old Nov 2, 2009 | 08:43 PM
BiG ChOr!Zo's Avatar
graphite gets messy if it gets bad and a metal one doesn't...!!!
Old Nov 4, 2009 | 11:41 AM
StylEmon's Avatar
doesn't the graphite one seal better on older motors tho?
Old Nov 4, 2009 | 11:52 AM
4drEF's Avatar
Keyboard Humorist
I don't think age matters.
If your motor or head is warped then you shouldn't try patching the problem by changing the material of the headgasket.
It will probably just blow again anyway.
Old Nov 4, 2009 | 12:04 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Yes sir.
Also since it's a touch thinner and better made run one for a z6 or y8.
Old Nov 4, 2009 | 12:54 PM
StylEmon's Avatar
I hear ya on trying to fix the actual problem, but in some cases, would think the softer gasket would be more forgiving of minor (with-in spec) irregularities.... could be wrong tho.
Old Nov 4, 2009 | 03:06 PM
89s1's Avatar
Check surface of the block with feelers and a trusted straight edge, get the head milled for a bit more fun factor at the same time then run a layer of copper spray to seal up any imperfections.
Badda boom, badda bing.
Also, as mentioned, definitely use the z6/78 metal gasket too.
Old Nov 4, 2009 | 06:52 PM
elchapin's Avatar
I got a z6 gasket and I will be getting some cooper spray
Old Nov 4, 2009 | 09:16 PM
96gts4.6l's Avatar
Post some pics of the work you're doing...
Old Nov 4, 2009 | 09:41 PM
efjones9's Avatar
(Thread jack) lol
How could u tell the diffrence between a d16a6 head and a jdm zc head?
Old Nov 4, 2009 | 10:25 PM
Originally Posted by efjones9
(Thread jack) lol
HEAD CODE STAMP DIFFERENCES:
D15B2
90 LX D15B2 5sp--------------PM3-9 (9/0) stamped rs of code
91 DX D15b2 5sp---------------PM8-12
93 EG4(EDM) D15B2 5sp-------PM3-8 (9/4) stamp
D16A6
88 RT D16A6 Auto------PM3-7
90 Si 5spd---------------PM3-1
90 Si D16A6 5sp--------PM3-4
ZC SOHC
88-91 ZC SOHC--------PM3-3
Old Nov 4, 2009 | 10:29 PM
90RENOsedan's Avatar
D15B2
D16A6
ZC SOHC
i wonder where the casting for an ex sedan would be?
Old Nov 4, 2009 | 10:37 PM
same as a d16a6 head
Old Nov 4, 2009 | 10:38 PM
pm3-1,7,or 4?
just trying to expand my knowledge.
Old Nov 4, 2009 | 10:52 PM
pm3-1,7,or 4?
thats what it says...!!!
Old Nov 4, 2009 | 11:05 PM
haha. got it.
Old Nov 5, 2009 | 07:04 AM
efjones9's Avatar
Thanx chorizo I still want that zc head from u!
Old Nov 5, 2009 | 11:05 AM
its still here sitting in my garage next to my si tranny
Old Nov 5, 2009 | 11:57 AM
96gts4.6l's Avatar
D15B2
D16A6
ZC SOHC
I'm not even sure I'd call this a correction, or rather perhaps an addition... My SOHC ZC engine (non-vtec) has a head code of PM3-10. Not sure what that really means, but I've yet to find someone else with this head code. The engine and head have never been apart.
Old Nov 5, 2009 | 12:00 PM
google search copy and paste owns everyone...the last three zc sohc heads i have run into each had pm3-3 but their might be other versions like yours...!!!
Old Nov 6, 2009 | 09:39 AM
StylEmon's Avatar
to put this back on topic, what is the benefit of the metal gasket? Just the toughness?
And could you use copper spray on a composite gasket?
Old Nov 6, 2009 | 10:20 AM
4drEF's Avatar
Keyboard Humorist
You can use copper spary on anything you want.
It's just bonus protection.
Metal lasts longer and is tougher like you said.
crxsirg
Jun 15, 2011 03:42 PM
Wheelman-CZ
Nov 15, 2006 04:41 AM
teamner
Apr 15, 2005 12:19 AM
Gumbey75
Feb 28, 2005 06:17 PM
crxhybrid85
Aug 8, 2004 10:21 AM
