New Slave, basiclly new MC, bled 3 times, still nothing..help
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/clutch-help-needed-asap-2674346/
I dont know what the deal is. Has pressure but it doesnt have enough to engage the clutch. The pedal has alot of play in it and wont spring back to the normal position. I cant get it into any gear but when i turn the car off i can.
Help with this hassle!!! Iv read it may be the clutch or pressure plate?
It seems that you forgot the first important step on installing your master cylinder. Check/adjust the shaft length to the original. It's not the end of the world, now it's just a pain to do.
Adjust the master clutch cylinder shaft under the dash. It uses a 10mm nut i believe, just loosen it and use a plier to turn it. If you turn it the correct way it will bring your clutch pedal back out.
