i need help
Check to see if you are getting power to your Ignition Module. If you are, then it is most likely bad. (Yes, I did say that right.) Check your main relay and all of your fuses too.
it's the pick up coil/ignitor inside the dizzy, mine did that the day i bought it and brought it home, thought it was the injectors but it ended up being one of the wires came off of the coil and wasn't sparking...try another coil that you know is good and if it works there you go...if not then you know it's your dizzy
bullwinkle777
Jul 21, 2007 06:18 PM
savedsol
Mar 16, 2007 04:44 AM
hurleyboarder21
Apr 12, 2004 07:22 PM
