Weird Noise when trying to start my car
Old Nov 2, 2009 | 05:12 AM
ed4doorcivic's Avatar
Default Weird Noise when trying to start my car
Well my brother and i put everything back together after the new clutch and gasket set, well when we went to start the car there is a loud BUZZING noise, i think it has something to do with the dizzy wires, Im just wondering if anyone has delt with this before, and what i could do to fix it fast? Thanks for any help
Old Nov 2, 2009 | 11:08 AM
Default Re: Weird Noise when trying to start my car
anyone?
Old Nov 2, 2009 | 07:05 PM
?????? has anyone came across anything similar to this, when u turn the key to power, it makes a buzzing noise and the check engine light comes on, any advise?
Old Nov 2, 2009 | 07:07 PM
90RENOsedan's Avatar
if you're getting a cel, check what code it is.
Old Nov 2, 2009 | 07:26 PM
scottmog's Avatar
lmfao that is totally normal, in the #2 key position correct?
that is the fuel pump primeing haha. it if is loud i suggest buying another fuel pump and keeping it in the car. then since yours is going out, when it does die, you can replace it
my car did this exact same thing last year, after the loud noise started my fuel pump lasted about a month before it wouldnt start.
Old Nov 2, 2009 | 08:39 PM
*Ej2*Luis's Avatar
sounds like a main relay.
Old Nov 3, 2009 | 07:00 AM
i dont think its a fuel pump, i have heard a loud fuel pump and its a different sound, plus when i go to start it my bro messes with the wire harness that is by the dizzy and it will go away, I know its common knowledge to say , WELL THERE UR PROBLEM, but i was just wondering if anyone has come across this and to see what to do fast.
thanks guys
Old Nov 3, 2009 | 07:19 AM
scottmog's Avatar
thanks guys
fuel pump primes for about one entire second when you turn your key to position two.
the main relay only clicks, nothing more, no sound longer. so no it isnt your main relay.
no if your car isnt starting and its silent, then its probably a main relay not clicking on.
ive been through fuel pump and main relay swaps about 3 times, and its the same sounds everytime. fuel pumps do sound sorta loud when they are dying, some times higher pitch then others. it doesnt have to be the exact same sound that you had last time. but if it is the problem when you turn the key to #2 and it lasts for about an entire second, it is the fuel pump whether or not you want to accept it lol.
Old Nov 3, 2009 | 07:22 AM
accept what? im saying that the sound goes away when my brother moves sum wires around that are located right next to the dizzy, and if he takes his hand off the wires then the noise will start again, im not saying its not the fuel pump, the damn car has 229k on it, im just saying the noise comes from whatever these wires blah blah blah, just went brain dead my bad.
Old Nov 3, 2009 | 08:37 AM
jonnyt1130's Avatar
sounds like the main relay...or it sounds like you have a loose ground wire. check and make sure all your grounds are tight
Old Nov 3, 2009 | 03:16 PM
kwill's Avatar
^ That was the problem the grounds on the thermostat housing were loose. Good call. Thanks for the help.
Old Nov 3, 2009 | 03:22 PM
shawn_crx's Avatar
guy got 2 account....
Old Nov 3, 2009 | 04:50 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
No, I would have to assume that it is his brother. The reason behind my assumption is that the grammar and typing skills are much better than the original. This suggests it is two different people, or he is schizophrenic.
Old Nov 3, 2009 | 07:20 PM
CORRECT its my brother, and u should stay out of ALL MY THREADS!
I really dislike you, Just saying if u see my name on a thread just stay out of it.
so i know ur a old man so respect my **** and stay out
Old Nov 3, 2009 | 08:16 PM
FinalBoss's Avatar
New User
Main relay or you have a ground wire off somewhere.
Old Nov 3, 2009 | 08:27 PM
BiG ChOr!Zo's Avatar
Old Nov 3, 2009 | 08:55 PM
scottmog's Avatar
since this thread is over might as well kill it with a long cat.
Old Nov 4, 2009 | 04:39 AM
^^^^hmmmm...thanks for that
Old Nov 4, 2009 | 01:04 PM
DO IT ON ALL FOURS
Heh... I don't pay attention to the threads I post to on this site. I don't even know who you are or why you dislike me (nor do I care). I don't remember half of the people I get into spats with. So I will try and remember who you are; BUT you should return the favor and do not post in or read any threads that I am apart of. My intelligence is probably too much for you to handle. When I am not making kids cry, I post extremely useful information. I do after all PWN it.
Old Nov 4, 2009 | 03:16 PM
well for the best I will just squash anything, and im not a kid, but im not an old man, so I can forgive u for all the dumb **** u say and I will make peace with u and go on from here and be joyful when i see u in the same thread
YAY!
Old Nov 4, 2009 | 03:55 PM
DO IT ON ALL FOURS
OK, sounds good to me.
Nooch
Dec 24, 2010 05:36 AM
byjl
11
Nov 2, 2008 10:40 PM
uses0ap
Oct 26, 2008 09:34 PM
superbangkok
Oct 6, 2006 08:46 AM
94JadeAccord
Dec 1, 2003 07:33 AM
