99civic no spark
99 civic lx with a jdm d15 obd1 engine no spark at all did the ckf sensor wiring and even has a brand new dizzy car was an auto did the wiring for the auto to manual swap any one have an idea i am waiting for the jumper harness so i can use an obd1 ecu i also checked to see if i was getting power to the dizzy which i am all fuses are good as well
Check the grounds. List any mods. Post how you determined that there is no spark. Did you reuse any parts from the old distributor? Is the fuel pump priming when the key is turned?
dizzy king on ebay has some good dizzys..im runnin one and have been for 2years now with no problems..i'd check fuel pump..or hell.check your dizzy plug..is it plugged in good?
Any CEL codes?
For 98-00 Civics, the Blk/Yel wire supplies power to the distributor and is protected by 15A fuse #9 under the dash. Check whether this fuse is blown. If the fuse is fine, check whether the Blk/Yel wire attached to the coil and igniter unit inside the distributor has battery voltage with the key in ON(II)? Also, what voltage do you measure on the Yel/Grn wire attached to the igniter unit?
kenneth4g4d
19
Jul 4, 2014 05:54 PM
