help! only running on 3 cylinders
ok so lastnite i was driving down the turn pike and my car bogged out.this moirning i was checking my cylinders and i lost compression to a cylinder.i checked the spark plug and it was fine.anything else u can reccomend?
did you add oil and retest the affected cylinder to see if compression went up? if it doesn't go up, then the compression is being lost through the top end. if it does go up, then the rings are shot. rebuild it or swap a different engine in.
Lamchop0000
28
Jul 7, 2006 06:50 PM
cxVtecC1
Feb 18, 2005 06:54 AM
street dreams
Nov 21, 2004 02:44 PM
Death_to_Thieves
Sep 25, 2002 12:49 PM
