Steering rack question.
Old Nov 1, 2009 | 10:32 AM
NOman0608's Avatar
Default Steering rack question.
I have a 99 civic si and my power steering rack is no good.
I am swaping a K motor in it and want to delete the power steering.
What I need to know is, is there a way I can put manual rack that will bolt up to the EM1 Subframe?
I was wondering if there is way because I do not want to loop it. If there is not other way, I guess I'll take the time and buy a new power and loop them.
Any info, experience, links, and such would be great!
TIA
Old Nov 1, 2009 | 10:35 AM
MR.johnson's Avatar
Default Re: Steering rack question.
if your swapping a K use an EG subframe and non-power rack. bolts right up.
Old Nov 1, 2009 | 10:45 AM
NOman0608's Avatar
I was told you have to use front lower control arms, forks, and such to run the front sway bar?
Is this true?
Old Nov 1, 2009 | 10:57 AM
SergEK's Avatar
Quick Edit -- get the pinion upgrade too so its quicker...I forgot who makes it but cuts the lock to lock
AlexintegraGS-R
Jan 7, 2007 05:26 PM
Dublocivic
Nov 3, 2005 01:57 PM
