auto to manual 92 -95 civic
Old Nov 1, 2009 | 09:50 AM
Your Name's Avatar
Default auto to manual 92 -95 civic
i am throwing a gsr into a eg that was auto sohc.
i know one mount has to be changed. tranny mount
but dose the rear mount have to be changed? or is it the same?
the mount thats a the rack.
lmk thanks
Old Nov 1, 2009 | 10:00 AM
Linked's Avatar
Default Re: auto to manual 92 -95 civic
with 3k posts man, you should know how to search
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-official-parts-list-auto-manual-swap-eg-1316692/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
Old Nov 1, 2009 | 10:57 AM
Your Name's Avatar
they say nothing about the rear mount.. maybe u should learn to read there post.
Old Nov 1, 2009 | 10:58 AM
Linked's Avatar
if they say nohing about the rear mount then i wonder what that means
edit: if the auto to manual swap doesnt require the rear mount to be changed (meaning the rear mount is the same on both models)
then do you need to find out if the rear moun needs to be changed when swapped to a gsr
(rear auto - manual mounts are the same to answer part of your question)
Old Nov 1, 2009 | 12:44 PM
xkrazyxjbrkerx75's Avatar
rear mount should be the same, the front passenger mount should be different
Old Nov 1, 2009 | 01:23 PM
RagnarX's Avatar
rear mount is the same, just the upper tranny mount has to be changed. I've done the swap. Alternatively you could cut the pocket mount and weld in the manual one, then you could use the oem manual mount but thats too much work.
streethondar
Aug 27, 2010 07:21 PM
benphillips
Apr 26, 2007 07:23 PM
DR Honda97
Mar 26, 2006 10:37 PM
kin6david
Jan 13, 2004 12:10 AM
