USDM to JDM swap questions
Old Nov 1, 2009 | 07:13 AM
Left_Sock's Avatar
Default USDM to JDM swap questions
Hey guys,
Well a few months ago my intake sucked in a big pile of water, hydrolocked the motor, bent 3 rods, busted one off and put a hole in the block SO she's toast. I had a 1995 B18C1 and I was wondering if I put a B18C (JDM) engine in it will my stock computer and harness's work or will I need to swap them also?
Thanks in advance
Old Nov 1, 2009 | 07:27 AM
weavertime1's Avatar
Default Re: USDM to JDM swap questions
Your stock harness and ecu will work just fine as long as you are getting an OBD1 JDM engine. If not there will be a few things that will have to be switched off of your engine like the distributor, injectors, and the alternator as they have different plug types from OBD1 to OBD2. Good luck with your swap!
Old Nov 1, 2009 | 07:31 AM
Left_Sock's Avatar
Thanks a lot, I did save all those parts so hopefully im good to go.
Uljima
Apr 17, 2014 11:24 PM
imcnblu
19
Feb 19, 2012 05:58 PM
JBirch_97Prelude
May 30, 2006 06:38 AM
cimet
Nov 14, 2001 02:34 PM
