b18b 96 civic ex wiring??
Old Nov 1, 2009 | 05:19 AM
vtecbanger's Avatar
Icon2 b18b 96 civic ex wiring??
I have a 99ls motor in a 96 civic ex. I hooked up the o2 and cfk. there is a 2 wire connector that plugs into the civic intake temp sensor and the purge on top of the ls intake manifold. I plugged the the connector into the civic intake temp sensor the car runs good. The problem I have is, I don't see a connector for the intake purge. If any one has pictures or advice it would be a big help.
Old Nov 2, 2009 | 02:28 AM
vtecbanger's Avatar
Default Re: b18b 96 civic ex wiring??
Is this in the wrong spot or am I the the only one on this forum with an ls motor in a civic?
Old Nov 3, 2009 | 02:24 PM
vtecbanger's Avatar
some please tell me if i need to run seprate wires to the ecu.
Old Nov 7, 2009 | 04:35 PM
cruizinmax's Avatar
You don't need to run separate wires to the ecu. Your stock harness should have a plug that goes to the evap purge solenoid. Which IAT sensor did you use, the stock civic one in the intake arm or the one in the integra intake manifold?
cjmegaman81
May 30, 2015 04:49 AM
LilLowEK
Jun 6, 2013 02:44 PM
JoshM3357
Mar 17, 2009 07:14 AM
red_hatchback
Jul 11, 2005 08:45 PM
type Gendy
Apr 22, 2004 10:13 AM
