Rebuilt Motor Wont Start
Old Oct 31, 2009 | 02:46 PM
I Love My 4 door's Avatar
Default Rebuilt Motor Wont Start
Hello HT, Im in need of help. I just rebuilt my motor and dropped it in, hooked up all sensors, put on intake manifold and headers. filled all fluids, full tank of gas.. It wont start !! Im jumping my battery ffrom sitting, my blinkers,hazards, power windows and locks, windshield wipers. all that stuff works. The only thing going on under the hood is the radiator fan going on. nothing from the started or fuel pump. did I overlook anything on my first rebuild ? Thanks for any ideas
Old Oct 31, 2009 | 05:09 PM
Former User's Avatar
Default Re: Rebuilt Motor Wont Start
Did you forget to connect the important ground wires on the thermostat housing (G101) and on the transmission (G3)?
Old Oct 31, 2009 | 06:29 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you arent even cranking, look at the grounds. because if you have the chassis ground hooked up, and the engine ground isnt, it may not crank.
and remember you need
4 things to run
fuel
air
compression
correct ignition timing.
Old Nov 1, 2009 | 04:41 PM
Checked all grounds, trans, starter, valve cover, thermostat, and I cant find out what wrong. Still no fuel pump, just my lights and blinkers and radiator fan. Now I hear a clicking on my ride side of the interior... could this be the ECU ? The car ran before I pulled the motor
Old Nov 1, 2009 | 04:48 PM
Check whether fuses 44 (hood), 31 (dash), or 13 (dash) is blown.
Old Nov 1, 2009 | 05:11 PM
all fuses are good even the 44,31, and 13. I heard a clicking from the motor for a seconds or two, but buzzing from the ECU. All wires are connected to ecu Im just worried thats the problem, like I said It ran before I pulled the motor.
Old Nov 1, 2009 | 07:09 PM
schock3's Avatar
main relay?
Old Nov 2, 2009 | 02:14 PM
Im attempting that in a few minutes, my brother has the same generation I do so he's letting me throw his relay in my car as a test. I just got a root canal so im waiting for my face to sorta un-numb haha. Ill let you guys know thank you
Old Nov 3, 2009 | 11:47 AM
Coolant and oil spewed out all over my driveway on first start. we'll see what the problem is now, any ideas ? Came out the back end of the motor
Old Nov 3, 2009 | 11:49 AM
thumper64's Avatar
giant gaping hole in the block?
Old Nov 3, 2009 | 12:08 PM
Old Nov 3, 2009 | 12:25 PM
roadsqueegy95's Avatar
umm oil from back of block....oil filter? you have all the rad hoses connected and tightened down?
Old Nov 5, 2009 | 09:18 AM
All hoses are tightened down, and just replaced with a better oil filter not the cheap pepboys one. Its cranking, but very slowly. It doesn't want to crank too hard to completely turn over, its just going real slow. My starter got a little hot so Im waiting for another try at it. thanks
Old Nov 5, 2009 | 09:23 AM
sde780's Avatar
what did you replace when you rebuilt it
Old Nov 5, 2009 | 10:02 AM
Oil pump, front a rear main seals, rod and main bearings, piston rings, honed the block, valve seals, head gasket, oil pan gasket, alternator belt, PS belt and got the crank polished.
Old Nov 5, 2009 | 01:13 PM
shogee's Avatar
sounds like a bearing clearance issue, plastigage any off the main bearings?, was the crank able to rotate freely after you got everything torqued down, all the caps on correctly, measure all of bearing journals for wear its so you can get the correct bearing sizes, have you rebuilt before or is it ur first one.
Old Nov 5, 2009 | 01:24 PM
sde780's Avatar
his starter and fuel pump should at least work
Old Nov 5, 2009 | 01:58 PM
kinny1's Avatar
New User
did it start i kinda have the same problem i still cant find out
Old Nov 5, 2009 | 02:18 PM
shogee's Avatar
bearing clearance
Old Nov 5, 2009 | 03:08 PM
I didnt build the motor, someone from NJ where I live who used to work at TurboTrix did. Dont even say that because Ill be pissed off cause I need this car for school, if its that Ill just give up now. i dont have time for it
Old Nov 5, 2009 | 03:09 PM
and kinny it did start but only ran for a few seconds and since then hasnt gotten enough ummphh to get it running again
Old Nov 5, 2009 | 06:54 PM
shogee's Avatar
yea but slow crank after a rebuild sounds like too tight of bearing clearance
Old Nov 7, 2009 | 08:30 AM
I checked my timing yesterday and this dumbass who built it was way, way off on the crank pulley timing marks.Unreal now Im just checking for a bent valve. But I don't think I have one
Old Nov 24, 2009 | 12:45 PM
rig9896's Avatar
If the valve isn't bent, you may want to check and do a valve adjustments job. If the valves are too tight, the car won't start either.
darkside_vtec
Oct 24, 2010 05:50 AM
TurboEK9Coupe
Apr 24, 2007 04:43 AM
drshottest718
Mar 26, 2007 03:47 PM
civic89si666
Sep 27, 2006 02:54 PM
