Need Help 1990 Prelude
Old Oct 30, 2009 | 12:25 PM
mcpabby's Avatar
New User
Default Need Help 1990 Prelude
what would cause the car to just shut down while driving and not start again?
Was driving down the road and then lost all power to the engine.... had power to lights and everything else..the engine just completely shut down, no check eninge light, no check oil light, no sputtering, just cut power.. Any ideas......
Old Oct 30, 2009 | 01:10 PM
bstiles88's Avatar
Default Re: Need Help 1990 Prelude
When was the last time you changed your timing belt?
Old Oct 30, 2009 | 01:20 PM
mcpabby's Avatar
New User
no just recently bought the car.. waiting to go tow it home tonight.. so trying to trouble shoot while being blind... it will try and turn of just wont fire... or start up.... i am thinking it's the timing belt... how hard is that to replace? thanks for your help...
Old Oct 30, 2009 | 03:09 PM
bstiles88's Avatar
Well if it did break it's not a simple "put it back on" type of deal. Wikipedia "interference engine" and do a little studying. Basically the valves and pistons share the same space, and if the timing gets off (i.e. timing belt breaks) you usually bend valves/dent pistons. In which case you have a lot of work to do.
Sometimes people get away with no damage, but since you kept cranking your car you're probably in trouble if that's indeed what happened.
Old Oct 30, 2009 | 03:20 PM
bigluelok's Avatar
check out prelude power(dot)com they can most likely help you with your problem
Boosted_B_Series
Nov 28, 2008 05:27 PM
s8an
Aug 6, 2004 11:16 PM
FastAssH22Accord
Mar 9, 2004 12:37 AM
Sephro
Sep 30, 2002 06:50 PM
96vteclude
Apr 4, 2002 05:27 PM
