CEL wont go out
Old Oct 30, 2009 | 11:00 AM
musTerdh22eg's Avatar
Default CEL wont go out
My CEL came on earlier this week. I checked it out and it says no codes so I tried to erase it and it wont erase.
Whats going on?
Old Oct 30, 2009 | 11:03 AM
Simkin314's Avatar
Default Re: CEL wont go out
Whats going on?
See if this applies to you...
http://wikitest.pgmfi.org/twiki/bin/...ootingSolidCEL
Old Oct 30, 2009 | 11:11 AM
also should have mentioned its a 96 ls
Old Oct 30, 2009 | 11:25 AM
Simkin314's Avatar
Originally Posted by Ls_dx
Solid CEL usually means bad ecu... do you have another socketed ECU you can try out?
I still would be focusing on the ecu portion of the vehicle.
Old Oct 30, 2009 | 11:28 AM
well i dont have another ecu laying around. is there anything else I can do
Old Oct 30, 2009 | 11:44 AM
Simkin314's Avatar
Hmm, well answer these first...
1) Is your car running?
1a) Does it run acceptably or poorly?
2) Is your ecu chipped/socketed?
2a) If so, did you socket it?
3) OBD2 right? (or have you done an OBD conversion)?
3a) If so, what ecu are you running?
4) USDM or JDM (large case or small case?)?
5) How many 'miles' are on the ecu? (i.e. is it possible it is a service engine soon light?)
I know, some of these questions may not be necessary but I don't like making assumptions...
Old Oct 30, 2009 | 06:02 PM
The car runs good (same as it did before the light came on). The car is stock and the light is the main't req'd light, which im pretty sure is the CEL. And it is OBD2. car has 152k miles
Old Oct 30, 2009 | 07:00 PM
kchungb17a's Avatar
Sorry buddy, the main't req'd light is NOT the CEL. Completely different. To check this, when you first turn your key to the 'ON' mode, you'll enter 'bulb check mode' where all the dash lights come on. You'll see there that the CEL is indeed not the MRL.
To reset the MRL (ideally after an oil change at least), reach with your right hand under the dash near where the knee bolster cover mates with the center dash. Underneath there, there is a module with a push button. While the key is in the 'ON' position, hold the button for 5-10 seconds. The light will turn off. If you need to you can see it if you stick your head under there.
Old Oct 30, 2009 | 07:14 PM
Simkin314's Avatar
Good call.
Old Oct 30, 2009 | 07:54 PM
mrdeadman's Avatar
They let me pick
The maint req light comes on every 7500 miles to alert you that you need an oil change.
Old Oct 30, 2009 | 08:59 PM
mouab18c1's Avatar
time to give it some fresh oil
Old Oct 30, 2009 | 09:04 PM
dntnedvtec's Avatar
To reset the light after you are done changing your oil, and anything else you might want to change at this time, (spark plugs, etc..) under the driver side of the dash, there is a little button, I think the case is green, black, or some color, and you just hit the little black button. There are some pictures around here if you look, and it shows you how to do it...it then resets the system, and begins to recount the mileage you put on, then after another 7500mi, bam! it comes on agian. ANy one please feel free to correct me if I am seriously wrong....
Old Oct 30, 2009 | 09:41 PM
ILS_09's Avatar
x2 follow these steps and it should go away
Old Oct 31, 2009 | 07:55 AM
thanks for the help guys
Old Oct 31, 2009 | 08:00 AM
Spawne32's Avatar
7500 miles? that was the stock interval for oil changes on this car, per acura? I always thought it was every 3000 miles
Old Oct 31, 2009 | 10:47 AM
mrdeadman's Avatar
They let me pick
In the manual it says 7500
350znal
Engine Management and Tuning
Feb 25, 2011 01:49 PM
rick_rabies
Aug 24, 2009 06:22 PM
h8tred
Jul 7, 2003 08:35 PM
B18EG6
Nov 8, 2002 07:22 AM
