LS crank in a B18C5?
Old Aug 30, 2002 | 12:09 PM
Boostless97Lude
Guest
Posts: n/a
Default can you LS stoke a B18C5???
like it says..... can you put an LS crank into a B18C5??? just the crank, not the rods.
Old Aug 30, 2002 | 12:11 PM
MK Ultra's Avatar
Default Re: can you LS stoke a B18C5??? (Boosted97Lude)
Absolutely not.
You HAVE to use LS sized rods unless you want to introduce your pistons to your cylinder head.
Old Aug 30, 2002 | 11:02 PM
lsvtec4door's Avatar
Default Re: can you LS stoke a B18C5??? (MK Ultra)
actually ls rods are longer then type r rods.....so u would have a problem with that....as far as the rest imnot sure
Old Aug 31, 2002 | 12:29 AM
MR. ARIZONA's Avatar
Default Re: can you LS stoke a B18C5??? (lsvtec4door)
Why would you wanna do that? Boost?
Old Aug 31, 2002 | 12:54 AM
sgT's Avatar
sgT
WHere do you people get your information from?
LS rods are SHORTER than GSR/ITR rods.
Old Oct 17, 2005 | 12:36 PM
miller.91.HB's Avatar
Default Re: can you LS stoke a B18C5??? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">WHere do you people get your information from?
LS rods are SHORTER than GSR/ITR rods.</TD></TR></TABLE>
Is this actually true, can anyone actually back that info up? I always thought oposite.
Old Oct 17, 2005 | 12:46 PM
migs's Avatar
Default Re: can you LS stoke a B18C5??? (miller.91.HB)
FWIW, I am actually doing this setup as we speak. LS rods are shorter.
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller.91.HB &raquo;</TD></TR><TR><TD CLASS="quote">Is this actually true, can anyone actually back that info up? I always thought oposite.</TD></TR></TABLE>
Think about it. Two blocks with the same deck height. They use pistons with pretty much the same compression height. The one with the longer stroke absolutely positively has to use shorter rods.
Old Oct 17, 2005 | 12:49 PM
Bradstard's Avatar
Default Re: can you LS stoke a B18C5??? (Boostless97Lude)
You need to use LS rods also. I'm running an LS crank and LS (length) rods in my B18C5.
Old Oct 17, 2005 | 12:55 PM
migs's Avatar
Default Re: can you LS stoke a B18C5??? (Bradstard)
Bradstard, what is your displacement when you did that? I am using USDM 81.25 pistons.
Old Oct 17, 2005 | 04:57 PM
ITRbroham's Avatar
shit post warrior
People get lulled into thinking that just because the B18B's crank has a longer stroke that the rods have to be longer also.
Modified by ITRbroham at 7:29 PM 10/17/2005
Old Oct 17, 2005 | 05:06 PM
uNF$@#!'s Avatar
holy batman digging up old threads from SGT who never posts on this board anymore
Old Oct 17, 2005 | 07:14 PM
Stein's Avatar
Default Re: can you LS stoke a B18C5??? (255.255.255.255)
At least he can't get told to search .
Old Oct 19, 2005 | 05:38 AM
migs's Avatar
Default Re: can you LS stoke a B18C5??? (Stein)
Bradstard, I saw somewhere saying that you had a 2.0 liter? Is that with the LS crank?
Old Oct 19, 2005 | 09:36 AM
Default Re: can you LS stoke a B18C5??? (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Think about it. Two blocks with the same deck height. They use pistons with pretty much the same compression height. The one with the longer stroke absolutely positively has to use shorter rods.</TD></TR></TABLE>
After seeing this and reading what you said that really makes sense. Thanks.
Old Oct 19, 2005 | 09:51 AM
(__________)'s Avatar
Default Re: can you LS stoke a B18C5??? (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Bradstard, I saw somewhere saying that you had a 2.0 liter? Is that with the LS crank? </TD></TR></TABLE>
Yes he is running a 85x89 setup
Old Oct 19, 2005 | 06:31 PM
migs's Avatar
Default Re: can you LS stoke a B18C5??? (Skinny Stevestard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skinny Stevestard &raquo;</TD></TR><TR><TD CLASS="quote">Yes he is running a 85x89 setup </TD></TR></TABLE>
85mm piston with an 89mm stroke? That makes 2.0?
Old Oct 19, 2005 | 09:16 PM
TypeSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;ac tually ls rods are longer then type r rods.....so u would have a problem with that....as far as the rest imnot sure&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
in one of the old tuning books, the section where people write in to ask questions in the back, in one of the answers asked by a subscriber they gave all the b series rod lengths. and im pretty sure the ls rods were the longest. and they are the same as the d series non vtec rods. but im just a noob what do i know.
Old Oct 20, 2005 | 04:29 AM
migs's Avatar
Default Re: can you LS stoke a B18C5??? (TypeSiR)
Well, I would have to say the tuning book is wrong.
Old Oct 20, 2005 | 05:11 AM
Bradstard's Avatar
85mm piston with an 89mm stroke? That makes 2.0?</TD></TR></TABLE>
I don't remember the exact displacement, but it's a tick over 2.0L. The B20 block is an 84x89.
Old Oct 20, 2005 | 05:20 AM
migs's Avatar
This is how I am thinking.
B20 = LS crank
84mm = LS/GSR/ITR pistons
85mm = B20 pistons
If all above equations are true, wouldnt
84.5mm pistons = 1.9?
Old Oct 20, 2005 | 05:21 AM
Hybrid ctr's Avatar
85*89 = 2020CC = 2.02L
Formula: Bore X Bore X Stroke X 0.0031416 = Displacement in CC
Old Oct 20, 2005 | 05:22 AM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">This is how I am thinking.
B20 = LS crank
85mm = B20 pistons
LS/GSR/ITR pistons are 81mm.
B20 pistons are 84mm.
strawberry
Jan 14, 2008 01:28 PM
Mfoehrkolb
Nov 21, 2007 05:37 PM
TurboEH2
Apr 2, 2005 11:15 AM
Greg-s
Dec 28, 2004 10:11 AM
BumpinVTEC
Dec 15, 2004 07:22 PM
