Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic climate fault code 9
Old Oct 29, 2009 | 09:55 AM
dnicholsjr's Avatar
New User
Default 2002 Civic climate fault code 9
Hi All,
I have a 2002 Civic LX 144K that the heat quit working. Lots of air, just blows cold. I flushed the heater core, diverter valve working fine, changed thermostat, but still blows cold. No leaks. I tested the climate control system and a fault code of 9 came up. Any ideas anyone? Thanks!
Old Oct 29, 2009 | 11:02 AM
dnicholsjr's Avatar
New User
Default Re: 2002 Civic climate fault code 9
I have since found out ot is either the air mix motor.linkage, or door. Any insights?
Old Oct 29, 2009 | 02:53 PM
It Wasn't Me's Avatar
1. Test the air mix control motor.
- Does it work?
Yes: Swap your heater control panel with one that works. If the problem goes away, replace your original hcp.
No: Go to step 2
2. Remove the air mix control motor.
3. Test the amc linkage and door for smooth movement.
- Do the linkage and door move smoothly?
Yes: Replace the air mix control motor.
No: Repair the air mix control linkage and door.
JD CRV
Honda CR-V & Element
Jan 20, 2019 06:00 PM
moz92
Jan 4, 2010 08:41 PM
erikiksaz1
Mar 12, 2006 08:19 PM
simplypinoyy
Feb 26, 2006 09:50 PM
