What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi?
Old Aug 30, 2002 | 11:17 AM
LoudAccord's Avatar
Default What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi?
and without using n2o! I am thinking of selling my hybrid accord and getting a civic with either a built H22a, or turbo h23, or SC'd B18c1... but what would get me into the 12s, and keep my car reliable for daily driving? any suggestions?
Thanks.
Old Aug 30, 2002 | 02:27 PM
H22EK's Avatar
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (LoudAccord)
go with the built h22 with high comp good cams and a lot of machine work in an eg hatch and you got it easy,sure you can get mid to low 11's
Old Aug 30, 2002 | 02:32 PM
hybridreams's Avatar
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (H22EK)
12s are easy
I plan on hitting it at my next race in a few weeks
Here's my setup:
92 CX hatch
Skunk2 coil overs
No rear seats/rear seatbelts
00 B18C1
Place Racing rear solid engine mount
AEM CAI
Skunk2 intake manifold
Skunk2 ECU chip
DC sports race header
Quaife LSD
Action SR clutch w/Clutchmasters flywheel
M&H slicks on bogart drag on flys
13x8x22
Old Aug 30, 2002 | 04:25 PM
Jonathan_ED3's Avatar
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (hybridreams)
12s are easy
Here's my setup:
92 CX hatch
Skunk2 coil overs
00 B18C1
AEM CAI
Skunk2 ECU chip
Quaife LSD
13x8x22
12's...?
highly unlikely. People such setups are usually hitting MAYBEEEEEEEEEEE 13.7
h22 and a set of slicks. Pretty easy. b18c5 would do it too.
EDIT: I just now saw skunk2 IM and ecu w/race header....I guess on slicks and a perfect run you could do 12.9x or so
[Modified by hot_EG, 1:26 AM 8/31/2002]
Old Aug 30, 2002 | 06:05 PM
97hb's Avatar
A b18b and turbo would be cheaper than any you listed and be in the 12's with slicks and the RIGHT driver. For daily driving, anything with boost needs more care than N/A.
Old Aug 30, 2002 | 07:37 PM
1 2 NV's Avatar
[QUOTE]go with the built h22 with high comp good cams and a lot of machine work in an eg hatch and you got it easy,sure you can get mid to low 11's[/QUOTE
he said cheap.
as far as hybrid dreams is concerned, it would b a fat chance in hell of hittin 12s with that setup, it wont yield high enough trap speeds. mid 13s at best.
Old Aug 30, 2002 | 10:51 PM
BoM's Avatar
BoM
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (hondaatwsu)
cx with any bseries swap + turbo
12's all day street tyres
Old Aug 31, 2002 | 01:25 AM
hybrider's Avatar
12s are easy
Here's my setup:
92 CX hatch
Skunk2 coil overs
00 B18C1
AEM CAI
Skunk2 ECU chip
Quaife LSD
13x8x22
good luck, you`ll need it.......................
Old Aug 31, 2002 | 02:46 AM
SiZ's Avatar
SiZ
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (hybrider93)
"Cheap, fast, reliable.. Choose two."
Old Aug 31, 2002 | 09:47 AM
~ZoSo~'s Avatar
Default Re: What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi? (SiZ)
wow that actually works perfectlly =]
Old Aug 31, 2002 | 03:39 PM
Civicboy's Avatar
Thats what I was going to say. I was going to say choose one.
[Modified by Civicboy, 4:40 PM 8/31/2002]
Honda24noobish
Honda Civic (2006 - 2015)
67
Mar 11, 2010 04:38 PM
MidnightB16
Suspension & Brakes
Feb 14, 2009 10:18 PM
athbaseball23
Aug 31, 2006 09:15 AM
hybridreams
25
Aug 24, 2002 10:51 PM
