spongy brakes
i was driving home today and i steped on the brakes and the pedal went all the way to the floor. i havnt done any work on the brakes so i know there is no air in the system. they where working fine yesterday. the resvoir is full of fluid. no leaks on any of the lines. i just wanted to get some input before i start buying stuff. could it be that the master cylinder is bad?
yeah i pumped the brakes with the car off as if i would bleed the brakes it makes this like weird buzzing sound when it is releaseing the pressure and even after pumping the brakes the pedal still goes straight to the floor. since the mc might be the case i have been wanting to upgrade and have access to a DA. is it even an upgrade to us the da brake booster and mc, will it fit?
You get a larger bore MC which is able to push more fluid out to the wheels.
Sounds like an upgrade - BUT - since you are still using stock brakes all that is going to happen is that you will not have to press the pedal down as far as you normally would have to for the same amount of braking.
Still sounds a bit like an upgrade - BUT - the reduced pedal travel reduces the distance you need to press down to lock up the brakes and skid... which is bad. If the MC was HUGE and you only had to 1/2 inch of pedal travel before it would lock the wheels then stopping the car properly would be extremely difficult. No, the DA stuff won't make it THAT bad, but I exaggerated it to give the image to consider.
In tight situations or in racing you want the some travel so you can modulate the brakes for efficient braking and avoid skidding.
Upgrade to the DA knuckles and calipers up front and discs in the back (along with the 40/40 proportioning valve) and you will be braking just like it was designed to.
Honestly I just had the same problem , 75 buck alter still no brakes , evenw tih a new MC , Check and see if fluid is coming out of the rear drums anywhere , I had a blown wheel cylinders on both sides
1sikhatch
Dec 7, 2009 04:18 AM
jasonweaver88
Jun 29, 2007 10:31 AM
