rota rb wheels
Old Oct 28, 2009 | 06:24 PM
aaronboy123's Avatar
Default rota rb wheels
hey guy, im trying to see which rota rb wheels will fit on my 2000 civic ex.
they have alot of different sizes i dont really get it?
15x7 4x114.3 +12mm offset 73mm bore?
15x7 4x100 + 13mm offset 57.1mm bore?
15x7 4x100 + 20mm offset 57.1mm bore?
15x7 4x114.3 + 25mm offset 57.1mm bore?
and more...
i dont get it? whats the difference? and what will fit on my car?
thanks.
Old Oct 28, 2009 | 06:31 PM
93egSLEEPER's Avatar
Default Re: rota rb wheels
the only ones that will fit your car are the 4x100 lug patters. the offset is the amount of "lip" on the inside and outside of the wheel. the lower the number the deeper the lip on the outside will be. stock offset is +45mm so thats just a reference to how the offsets will compare.
fastrxu's Avatar
Any of the 4x100
The offset(how they stick out) is totally up to you
Old Oct 28, 2009 | 06:33 PM
k so the +"whatever"mm is the offset not the other number?
Old Oct 28, 2009 | 06:35 PM
i dont want it sticking out and the highest they have is +35mm so i guess thats good enough?
yea. 4x100 is lug pattern. #mm is offset and the bore is the size of the lug holes
Old Oct 28, 2009 | 06:38 PM
here is a +35 on my civic lowered about 2.5 inches.
Old Oct 28, 2009 | 06:40 PM
so if i get the 15x7 4x100 +35mm offset 67.1mm bore. does it matter which gorilla lug nuts i get they have 12x1.5 n 12x1.25?
Old Oct 28, 2009 | 06:41 PM
its thread pitch*? whats that?srry bout all the questions.
Old Oct 28, 2009 | 06:42 PM
its my first time getting wheels.
Old Oct 28, 2009 | 06:43 PM
you need the 1.5 thread pitch. gorilla lugs IMO suck, they are so easy to get off and steal
Old Oct 28, 2009 | 06:44 PM
o really? should ig et the muteki then or the sr35? what size r ur wheels n bore size?
Old Oct 28, 2009 | 06:48 PM
my wheels are 16x7 +35mm offset. i dont know the bore size off the top of my head, probably the same as what your looking at. i have a set of rays lugs w/ rays locks. they make something like 50 different key combos so they are harder to get off. make sure you get set of good wheel locks. cheap ones are easy to break off
Old Oct 28, 2009 | 06:52 PM
o i see.i bet rays cost alot of $$ too lol.
wat do u perfer 15" or 16" wheels? i cant make up my mind?
Old Oct 28, 2009 | 06:57 PM
both look nice man. just depends on how much tire you wanna have. 15's will be a bit quieter and a softer ride. i like 16's because they have decent meat for tire, still semi low profile and adds a lil bit of flash. its up to you. i got my lugs for 130 shipped. a good investment when i have 700 in tires and 500 i wheels
Old Oct 28, 2009 | 07:04 PM
wow! lol
u have the short rays 35mm or the extended 50mm? whats the difference?
they have a 20pc kit her includs the lock too?for $179 but if u call they said they can give u a better price, if u get it together with wheels.
im sorry 139$ for short 179$ for extended*
Old Oct 28, 2009 | 07:05 PM
i have the extended ones. i got mine for waaay less then 179 though. look at inline4.com
Old Oct 28, 2009 | 07:13 PM
k hey thanks for the help n info man. hopefully everything goes well i g2g getting late.
matsgsr
Jan 18, 2011 07:17 AM
wytiak3
Jan 4, 2006 09:47 AM
poweredbyhonda604
Jan 25, 2003 07:46 PM
RacerBoy
Dec 9, 2002 04:43 AM
tampaSi
May 10, 2002 04:06 PM
