Rear Disc Conversion
Old Oct 28, 2009 | 02:57 PM
azandford's Avatar
Default Rear Disc Conversion
The guy who sold me my car let me know that he has a new rear disc conversion for the car that he wants to let go for 200 bucks. Am i going to notice a big difference in braking w/ rear discs. How much extra weight does it usually add. Is it worth all the effort and money ?
Old Oct 28, 2009 | 03:01 PM
gsrhatch2356's Avatar
Default Re: Rear Disc Conversion
it does not affect braking that much unless you upgrade to the 40\40 valve and a bigger master cly. it takes more pressure and more fluid to make the rear disc to work over the rear drums and so the 40\40 creates the pressure that it needs and then there is the volume of fluid which if you get the master cly of of a 1991 civic with abs then it will bolt up to 92-95 and maybe even 96-00 booster and it has a 15/16th bore.
Old Oct 28, 2009 | 03:08 PM
eg.ob's Avatar
200 bucks is a good deal, i'd take em up on that offer, like gsr hatch said, if you dont upgrade your valve, it'll be more of a show up grade than preformance.
Old Oct 28, 2009 | 03:10 PM
HCivExoo's Avatar
it can be worth the effort and money if you need and are tracking the car but if you are DD'n the car then you don't need it. the disc brakes are possibly even light than the drums to be honest with you, if there is a weight difference there isn't much of one.
you could find out the rotaional weight by weighing a drum and rear disc.
Old Oct 28, 2009 | 03:11 PM
I hate people that try to sell **** on this side so go check my for sale threads before you purchase
Old Oct 28, 2009 | 03:58 PM
joelmatt89's Avatar
your front brakes do the majority of the braking anyway if you want to upgrade braking i would go bigger in the front and and leave the drums in the back. Unless your pushing 300whp stock brakes should be fine for a dd. I would say there are better ways to spend that 200
Old Oct 28, 2009 | 04:11 PM
azandford's Avatar
i actually am pushing 300hp, maybe theres a future in reselling it. I saw one online i think an AEM model for about 1200
Old Oct 28, 2009 | 04:43 PM
joelmatt89's Avatar
well regardless rear disks really don't do much compared to upgrading the front, all i am saying is your money would be put to better use if it was spent on the front brakes.
Old Oct 29, 2009 | 06:47 AM
HCivExoo's Avatar
a good set of rotors that can take a beating and a good set of pads. even if you are running 300 hp if you never track the car it isn't going to matter.
Old Oct 29, 2009 | 09:31 AM
it is just as important to upgrade the front as it is to do the rear. If all you do is upgrade the front then the car will nose dive when braking and pull wieght and traction off of the rear and special if you road race the car then you need a good even braking so that the car stays as flat as possible during braking.
classdork987654
17
Oct 18, 2008 04:25 AM
Mr_Si-R
46
Nov 4, 2005 06:05 PM
turbob16a522
Jun 19, 2005 07:10 PM
EGhatched
10
Mar 31, 2004 08:45 AM
lastlude2k1se
10
Jan 17, 2003 12:19 PM
