Which ECU to buy for b16 ???
Old Oct 28, 2009 | 11:49 AM
EcRzFinesT's Avatar
Default Which ECU to buy for b16 ???
Hi, i have a 98 civic with a 00 si b16 swap. Im currently running a p73 ecu which burns crazy gas and seems to be overkill. Which ecu is my best shot at buying. I want something that will feed my b16 properly. I looked around and found that chipped p28 might be my best bet. Ps i currently have intake/headers/exhaust as mods.
thanks,
Old Oct 28, 2009 | 11:53 AM
98civdx's Avatar
Master Detailer
Default Re: Which ECU to buy for b16 ???
a p28 chipped and TUNED,
Old Oct 28, 2009 | 12:00 PM
EcRzFinesT's Avatar
all i need to have the p28 up and running is the conversion harness from obd2 to obd1 correct? I wont need to change my distributor or any thing right?
Old Oct 28, 2009 | 12:10 PM
98civdx's Avatar
Master Detailer
just get a juimper. you need a obd2a to obd1 harness, you can also use the stock si ecu, but you will still need a obd2a to 2b harness.
Old Oct 28, 2009 | 12:25 PM
barone's Avatar
i recently just got the stepdown harness to use a 95 ecu. i got a chipped p06 on crome tuned.. **** works mint. (00 civic si b16a2 with cold air intake.)
Old Oct 28, 2009 | 01:01 PM
EKcivicEK's Avatar
use the p30 ecu. comes from the del sol si with the b16a you will need a jumper harness. im running that ecu with a b16a2 and it runs perfect. no tune.
Old Oct 29, 2009 | 04:17 PM
EcRzFinesT's Avatar
i have looked into buying the p28 since ill be able to tune it better for my setup, and change the tune later down the road. However i see there are "P06 ECU converted to P28" ecus going for cheaper prices then the p28 ecus. Is there any cons in these ecu's?
Old Oct 29, 2009 | 04:30 PM
ANNiHiLATORS's Avatar
jumper harness obd2a to obd2b and buy a p2t em1 99-2000 or get a p28 chipped/tuned
wallendiaz
Mar 14, 2013 07:27 AM
EJ8FERIO
Aug 22, 2007 07:38 PM
EJ8FERIO
Aug 18, 2007 03:17 PM
B16SolMan
Sep 8, 2006 06:46 AM
JDMProjektSi
Feb 20, 2004 08:35 PM
