96 cx to v-tec, not sure if v-tec is worken
ihave put a d16y8 head on my d16y7 block, it only had 60000 miles so i figured i'd give it a try a lil at a time, well i only put the head on, no exhaust, intake, injectors, just the head, i tryed computer but it didn't wanna run right, so i put old one back and wired v-tec solenoid to 12 volts, if i do it while idling it sometimes wants to stall, so i figured it's worken, but at higher rpms, if i give it 12 volts, it does nothen at all, i can't hear nothen change and no extra power at all, none whatsoever, i think there's more power now from the head change though, i know i can feel a difference but i would just like to know if i'm gonna feel a change at all or not, i would not like to waste anymore money i don't have tryen to get this to work if it's not going to, thanx
well you should be able to hear the motor's pitch change, although its not that different like it is on B and K series.
And you will make more power than a stock Y7 because your compression is now in the 10's area instead of 9.4:1.
should i feel any difference in power or not? cause there is no difference at all, i'm wonderen if the v-tec solinoid is worken at all, i think i would notice some sort of power change if i have v-tec worken, with all the other upgrades or not i would think
y8 has weak vtec to begin with. I've had a lot of y8s there is no noticeable difference when vtec kicks in. h22 throws you in the seat when it kicks in and b16a2 there is a pretty big difference as well. not the y8s though... although they are one of my favorite motors.
sonson6
Dec 11, 2007 09:56 AM
civicracer1993
Jan 13, 2003 01:51 AM
