need help h22 wont start
well i got my h22 swap in my eg... when i start it it run fine like a champ but after the 4 time it die no power goin to the car...when you put the key in the on position the dash light are very dimm
and the battery is new
my friend said that it the starter that need to be replace or the wiring
Just because the battery is new doesn't mean anything you could have blown a cell. The starter would not make dash dim. Very well put ronj check your ground it could be loose. not just at the battery either check all grounds. advise after checked we can help you with this.
okay guy now i got my battery working full power but now when i try to start it ... it only does one click so im guessing it the starter???? cuz it doesnt crank
You could jump the starter and make sure that your wiring to the starter isn't bad. That way before you go out and buy a starter check simple things like wiring
