Progress Rear Sway Bar + Tie Bar
Old Oct 28, 2009 | 12:37 AM
tweek_boii's Avatar
Default Progress Rear Sway Bar + Tie Bar
Is the adjustable one really different ?
What should I have in order to install. Any heads up would be appreciated
Answer:
Non-Adjustable sway is 22 mm
Adjustable sway is 24 mm
Old Oct 28, 2009 | 04:08 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Progress Rear Sway Bar + Tie Bar
I've heard good things about the adjustable one but I think it's a bit over kill if you aren't a hardcore guy with a purpose built only for the track race car... I would just get a regular progress bar upgrade which is still very much noticeable and maybe adjustable endlinks and call it a day.
Old Oct 28, 2009 | 05:33 AM
WhiteOnRice's Avatar
2x
Old Oct 28, 2009 | 09:35 AM
turboteg2nv's Avatar
yup love my 24mm Progress sway bar. The 04-05 is different, so make sure you get the right part number.
Old Oct 28, 2009 | 10:35 AM
tweek_boii's Avatar
Installing wise, I usually break stuff. With that in mind should I worry about anything ?
Old Oct 28, 2009 | 06:08 PM
tweek_boii's Avatar
The end links that progress provides are garbage ?
Old Oct 28, 2009 | 06:36 PM
hawaiiancb74's Avatar
ehh they are just solid swivel.
Old Oct 28, 2009 | 07:45 PM
EPTech's Avatar
the endlinks arent included with the bar just bushings. at least from what their product description says
Old Oct 29, 2009 | 06:22 AM
I think the adjustable ones come with endlinks, but I'd double check just to be sure.
OP - install wise the only thing that will cause problems are the OEM endlinks, they rust like hell and are hard to come apart. Everything else is easy breezy so long as you can realign the lower control arms to get that bolt through. I just use the jack and pry bar to align the LCA with the subframe and push the bolt through. You'll see what i mean when you get there.
I salvaged one of the OEM endlinks, I could've got the other one but I knew I was going to replace it anyway so I just hacked it off with the cut-off wheel
I used the Corsport V.2 endlinks but I'm still not 100% satisfied with them (only $50 for the pair). The Hotchkis endlinks are where it's at but those are big $$
OEM endlinks are prone to breaking with the larger sway bars, they aren't designed to take that much load. I'd recommend replacing them with something.
Old Oct 29, 2009 | 11:00 AM
tweek_boii's Avatar
Ah thanks for the heads up and yes the adjustable version does come with endlinks, should i toss them and get different ones ?
http://www.clubrsx.com/cr/PRO-62-0103.html
Originally Posted by Progress Technology
Adjustment Range: 2 holes
End-links Included: Yes
Progress Suspension anti-roll bars dramatically improve handling. How? They minimize the traction-robbing body “lean” that rolls part of the outside tires off the pavement. Our Sport-tuned Anti-roll bars replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body “lean”, and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control! Less body roll means more traction, faster cornering speeds, and increased driver confidence. Polyurethane bushings produce crisp response on turn-in. Progress Anti-roll bars are cold-formed in-house using our custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
***Note: Box is considered oversized for shipping
***Note: Actual product may be different than pictured
Old Oct 29, 2009 | 12:46 PM
Don't toss them - I would use them. I just HAD to buy new ones because mine didn't come with them.
Old Oct 29, 2009 | 01:01 PM
josh's ep3's Avatar
Function > Form
lol ^^
Old Oct 31, 2009 | 12:44 PM
tweek_boii's Avatar
LOL i was checking out the reviews on club RSX and a lot of people said the endlinks were garbage?
Old Nov 2, 2009 | 09:25 AM
^^ Most likely. I'd pick up the Corsport V.2 just because they're cheap.
Old Nov 3, 2009 | 12:24 PM
CarsAddict's Avatar
you be fine i think you can adjust them all, no problem.
Old Nov 8, 2009 | 05:46 PM
kefka's Avatar
I've experienced some issues with this setup - a week or so after the install, the bar punched a hole in my gas tank filler hose and subsequently dumped a bunch of fuel onto my garage floor. I figured that the bar was sitting to high on its mounting points, so I loosed the bolts, pulled to the lowest point possible in the center and tightened everything back up. Luckily, I haven't had any additional issues...
Old Nov 9, 2009 | 04:41 AM
DIdn't you post this on EPhatch too? I remember reading about that. What was your setup that caused the problem exactly?
Old Nov 10, 2009 | 02:05 AM
kefka's Avatar
It was the combination of being too low and having the bar centered at the mounting point.
Old Nov 12, 2009 | 03:49 PM
tweek_boii's Avatar
The non adjustable not only is it non adjustable, its 22 mm
and the adjustable version is 24 mm
Very surprising !
Old Nov 13, 2009 | 06:31 AM
Very surprising !
Not surprising, just two different setups to give you more options based on your suspension goals.
24mm is rather aggressive for the street, if you aren't prepared to handle it.
ilvi3tkidxx
Feb 27, 2009 01:24 AM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
dj12oclock
Honda Civic (2006 - 2015)
Mar 19, 2008 12:19 AM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
