Help...What is this? Pic inside......
Old Oct 27, 2009 | 02:35 PM
EM1 Resto's Avatar
Default Help...What is this? Pic inside......
Question answered...Thanks!
Last edited by EM1 Resto; Oct 28, 2009 at 06:44 AM. Reason: Answered my own question
Old Oct 27, 2009 | 04:30 PM
madpipr's Avatar
Default Re: Help...What is this? Pic inside......
get a probe, a wiring diagram, and have at it. No real way to be sure what it is unless you get a diagram from where the wires come from.
Old Oct 27, 2009 | 04:37 PM
impound's Avatar
keyless module?
Old Oct 27, 2009 | 04:51 PM
fastrxu's Avatar
What does it say on the sticker?
Old Oct 27, 2009 | 08:03 PM
gwl's Avatar
gwl
That is some ugly wiring job. I would try to find each wire that they cut and pair them up one color at a time. Be sure to get a wiring diagram so you can check and cross them off on the ones you had to splice together. Also, use solder and heatshrink because you don't want to have any problems with loose connections.
Old Oct 27, 2009 | 09:44 PM
thumper64's Avatar
Don't remove that box, it's the flux capacitor and the car won't run without it.
Old Oct 27, 2009 | 11:18 PM
fastrxu's Avatar
Flux capacitor? Super jdm for time travel
Old Oct 28, 2009 | 12:23 AM
boost92eghatch's Avatar
Looks like a bomb.
Old Oct 28, 2009 | 03:20 AM
EM1 Resto's Avatar
It must be keyles entry now that I think of it. It says FCC compliant and the alarm has keyless entry. I'm trying to figure out where would the starter kill connect if it were being used. Would it connect to where the key solenoid is?
Old Oct 28, 2009 | 03:21 AM
EM1 Resto's Avatar
Old Oct 28, 2009 | 04:08 AM
alphalanos's Avatar
Originally Posted by EM1 Resto
It is more polite than the other word....I guess
keep that stuff out of the forum.
Old Oct 28, 2009 | 04:36 AM
gooberguy31's Avatar
it may help to look at your starter in your engine bay, my kill switch was wired right to the wiring on the starter, then ran through my car, maybe that will help. But yours looks like it is going to be wired in. GL with this Long and overly tedious process
Old Oct 28, 2009 | 05:00 AM
gen2tegboi's Avatar
Why couldn't you call it "Hillbilly rigged" I definitely think it would be more appropriate.
Old Oct 28, 2009 | 02:55 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by RonJ@HT
Is this a racial remark?
Sounds like it.
Old Oct 28, 2009 | 03:18 PM
HCivExoo's Avatar
back to the topic i am positive that is for the keyless entry to test disconnect and see if your keyless works?
Old Oct 28, 2009 | 03:43 PM
DOHCtorEK's Avatar
Yee straight explosives
ericrcan
Feb 29, 2012 04:30 PM
Topdawgg
Apr 11, 2007 10:10 AM
2slowCivic
Audio / Security / Video
Jun 1, 2003 11:58 AM
