Suspension & Brakes Theory, alignment, spring rates....
How To: 99 Si 26mm Sway Bar with EX LCA!!
Old Oct 27, 2009 | 12:10 PM
honisoto's Avatar
Default How To: 99 Si 26mm Sway Bar with EX LCA!!
I've been messing with sway bars back and forth and finally came up with a solution to using a FRONT 99 si 26mm sway bar on EX LCAs.
Parts List:
26mm front sway bar from a 99-00 Si..
92-96 Prelude VTEC front Endlinks
Tools:
1/2 drillbit
Drill
something to hold the sway bar nice and tight when you drill.
Now the thing is you need to drill the holes for the endlinks on the front si sway bar to 1/2 size drillbit and then you are good to go, just stick in the prelude endlinks and thats it! Before I've tried the front GSR endlinks and they were too short so the sway bar would rubb against the front LCA and now with the prelude endlinks, the clearance is pretty good! Just be sure to get some nice bushings for the endlinks!
HERE ARE THE PICTURES OF the CLEARANCE with PRELUDE front ENDLINKS. (perfect clearance right? ...yes of course. woot woot and this picture, the car was NOT on jacks)
*STICKY THIS IF YOU MUST* lol...
Old Oct 27, 2009 | 10:21 PM
gsr1379's Avatar
Default Re: How To: 99 Si 26mm Sway Bar with EX LCA!!
any chance for a pic of the LCA sway bar Clearance... I was trying to do this with Gsr endlinks and i have the rubbing issue
Old Oct 27, 2009 | 10:24 PM
honisoto's Avatar
Yeah I'll try to get up some pictures tomorrow.
Old Oct 29, 2009 | 02:15 AM
fastrxu's Avatar
Yes yes pics
Old Nov 1, 2009 | 05:18 PM
alphalanos's Avatar
thats a pretty big front bar. how is the balance with that.
Old Nov 1, 2009 | 09:09 PM
chuck chainz's Avatar
Good info, so are the gsr end links the same as type r? because if they are not it seems like that would work as well. si sway/ex lca/ type r links?
Old Nov 1, 2009 | 11:16 PM
honisoto's Avatar
Yes, Type-R and GSR use the same endlinks. As I said above, the Si sway bar will rub your LCA with the GSR/ITR endlinks. This is why I used the Prelude endlinks which prevents it from rubbing.
The 26mm front bar to me is so much better than the 22mm bar. If you have a CTR/ITR rear bar, the 26mm front bar would be perfect.
Old Nov 2, 2009 | 12:22 PM
ok thanks, thats good to know, i have been running si 26mm front and si 13mm rear, hopefully soon i can upgradw to at least a 22mm rear, or just get higher rates in the rear
Old Nov 2, 2009 | 04:09 PM
1.5Slowmatic's Avatar
hmmm if i ever upgrade from the rear EM1 bar this would be a good upgrade. In for pics
Old Nov 4, 2009 | 01:04 PM
honisoto's Avatar
PICTURES are up guys! hope this helps you guys who want to save some money instead of buying the stupid 99-00 front Si LCA.
Old Nov 4, 2009 | 08:17 PM
hows the feel on the street. What if any rear bar are you using?
Old Nov 5, 2009 | 05:19 PM
gsr1379's Avatar
great info thanks for the Pics!
Old Nov 8, 2009 | 10:16 PM
woder why honda didnt do this in the first place
Old Nov 8, 2009 | 11:34 PM
honisoto's Avatar
thanks for checking it out! The feel on the road is just like a CTR now that I installed the CTR rear sway bar too...i need better coilovers. lol...
Old Nov 9, 2009 | 07:06 PM
Airbag Club's Avatar
so do you think this would work vice versa... to put an EX sway bar on an EK with SI LCA's? I want to decrease the diameter of my front sway bar..
Old Nov 9, 2009 | 07:45 PM
wouldnt work because the sway bar ends are different... vertical for SI, and horizontal for EX and that's only the sway bar, the SI lca's have abracket welded to them, thus being only compatible with the SI sway bar
Old Nov 9, 2009 | 08:51 PM
but couldn't you just flip the endlink upside down?
Old Nov 10, 2009 | 07:33 PM
angel_i's Avatar
Perfect. I was thinking of using Integra Type R links.
Old Nov 10, 2009 | 09:17 PM
Drew2o2's Avatar
thanks now i dont have to buy the eibach 26mm bar
Old Nov 11, 2009 | 09:21 AM
honisoto's Avatar
Airbag, I believe that might work, but I wouldnt say It will because I havent tried that. Why go such small size? trust me, i had the 22mm front bar, I hate how soft it is....but then its up to you. lol..
To everyone else, glad I've saved your day.
Old Nov 13, 2009 | 09:48 PM
honisoto's Avatar
bump for noobs?
Old Nov 27, 2009 | 05:42 PM
JSPECSIR's Avatar
do you know if that sway bar will fit under an eg/dc chassis?
Old Nov 29, 2009 | 08:11 AM
Relic1's Avatar
yes it will, but I didn't like it even with the 23mm rear bar, too much push.
IMO, the 24mm front bar is a nice compromise.
honisoto - you can do the same with a heim joint, a bolt, and the lower half of the EG/EK link.
But I like keeping with the OEM parts.
Old Nov 29, 2009 | 09:46 AM
RyanA's Avatar
Nissan 240 endlinks work, too. They are just a bit longer than the Prelude ones.
rexman2002
10
Jul 6, 2009 11:08 AM
user 98292739
Mar 19, 2007 01:54 AM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
chino369
Suspension & Brakes
Feb 26, 2007 12:13 AM
NTGR8D
Mar 13, 2003 11:13 PM
