what kind of power would this make?
Old Oct 27, 2009 | 09:35 AM
a vtec life!!!'s Avatar
Default what kind of power would this make?
So I was cleaning up my garage yesterday and I had a ton of things laying around... I got a d15z1 block from a 92 vx, a d16y8 head with skunk2 manifold and b16 throttle body port matched to it with blox stage 2 cam and aem cam gear dsm blue top injectors, PM7 pistons from a d16a1 ZC motor, a stage 2 clutch and a d16z6 tranny and dc headers and aem cold air... im gonna run it on a p28 ecu stock... what head gasket should I use and what power range do you think this build would be in?
Old Oct 27, 2009 | 09:43 AM
Default Re: what kind of power would this make?
The purpose of the build is boredom by the way...
Old Oct 27, 2009 | 10:07 AM
Im also gonna throw a MSD setup on it.. Its the sport compaxt ignition (SCI) box with blaster coil
Old Oct 27, 2009 | 10:24 AM
vtechjunkie's Avatar
Mill the block and the head. You will get more compression out of it. Then get the thinnist head gasket you can get from Cometic. You should be able to pull around 160hp to the wheels with a good tune. Keep us informed on how it goes. Interested!
Old Oct 27, 2009 | 10:40 AM
How much of a mill you think?
Old Oct 27, 2009 | 10:58 AM
And should I get a head gasket for the y8 head or for the z1 block?
Old Oct 27, 2009 | 11:12 AM
solo227's Avatar
your prolly gonna lose power...
Old Oct 27, 2009 | 11:39 AM
I read your compression jumps to 12. Something with those piston as long as you use a y8 head.... I think its worth I shot, I got all the parts except a gasket, so its not gonna hurt my pockets
Old Oct 27, 2009 | 05:01 PM
Any other suggestions
Old Oct 27, 2009 | 05:29 PM
hondamark35's Avatar
check out o n e c a m o n l y . c o m
there are some very experienced guys spending all their efforts on similar builds. they'll be able to advise you based on first hand experience.
Old Oct 27, 2009 | 06:07 PM
^^^ good lookin out with that site...
Old Oct 28, 2009 | 11:03 AM
Might be using ls rods too, what you think?
Old Oct 28, 2009 | 06:11 PM
Scratch that, they're too wide for d15
rcoleman
Dec 29, 2011 11:00 PM
ProricanEF
Jun 7, 2009 10:30 PM
docmanakos
11
Apr 15, 2005 10:50 PM
BauleyCivic
May 31, 2003 10:39 AM
SPOON_BeIgHtEeNsEe
Jul 7, 2002 01:37 PM
