starting problem
ok so on my way to work the car ran fine parked it went into work came back out started right up and i went to run an errand got the turned the car off came back out maybe 10 minutes later and it wouldn't start so i went back inside to call a buddy to come tow me i went back out like ten minutes later and turned it over a couple of times and bam she fired up so i went on my way to the gas station turned it off it ran the whole way there fine turned it off pumped my gas got back in the car and it wouldnt start again waiting like 10-15 minutes and bom started up again does anyone know what the problem is
i know how to write complete sentences *******. and i checked all of that already, and it was also raining outside at the time. i first thought it could of been a crack in the dizzy cap. however when i looked at the cap it was good no cracks and was sealed all up
Check your start switched signal wire to your starter solenoid. I once had a similar problem where it was loose causing intermittent start-up capabilities. Another possibility is your starter solenoid contacts are going out on you.
