IAC or cooling system?! Please help
Old Oct 27, 2009 | 07:47 AM
mcki0068's Avatar
Icon6 IAC or cooling system?! Please help
When my car is cold it idles fine, but after its warm or after I bring the revs up then it seems to bounce up and down from 900-1200 rpms. Im not sure if it is my IAC or if its the cooling system at all. All vacuum lines seem intact. The top of my rad spits a bit of cooloant either cause the cap is screwed or the seal is going. I have to top it up weekly. Any thoughts would be appreciated!!!
Thanks
Old Oct 27, 2009 | 08:05 AM
skaternak's Avatar
Default Re: IAC or cooling system?! Please help
get a new rad cap and bleed it off. if problem persist, remove iacv and clean with carb cleaner
Old Oct 27, 2009 | 08:35 AM
slow96lude's Avatar
Get a new radiator cap first off. But usually the idle problem after warm up is due to the FITV not working properly. There is a little test you can do to see what is causeing the idle surges. Let the car warm up to operating temp. Then inside you TB right before the throttle plate there will be 2 holes about 1/2'' in dia. Top....IACV Bottom....FITV. Now that you have the car warmed up plug the bottom hole. If the idle smoothes then the FITV is fine. If there is no vac there then plug the IACV (top hole) and the engine should stall. If the engine doesnt stall then you sir have a vaccuum leak
Old Oct 27, 2009 | 08:41 AM
mcki0068's Avatar
thats great I'll check that tonight, thanks alot for your help
Old Oct 27, 2009 | 08:43 AM
slow96lude's Avatar
no prob bob
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
VTechLivin94
15
Mar 29, 2013 06:52 AM
Skyhigh07
Jan 15, 2009 11:48 AM
mikeunreal2
Mar 2, 2006 09:06 PM
