I'm we-todd-did, where does the brake fluid go???
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
My parking brake light says on while driving
so I think I need some brake fluid. Is there a hole to put it in or a container or something?
if you know where your clutch reservoir is.......look to the left......larger reservoir = brakes (or for those who are illiterate "breaks")
Is that the blue thing on the right? I can't see that well...is there a cover that just flips off and on?
marc, look at your strut bar in front. on the driver side mount area, look north. you will see 2 reservoirs.. both with "blue/black" caps. the larger one is brakes, smaller one is clutch. good luck
yeah the pics buttnickel just put up
[Modified by Soup ****, 12:01 PM 8/30/2002]
sometimes its marked "oil" on your valve cover (red thing under hood)......just pour a good amount in there, or like Sean said.......directly on the pads
then drive at high rates of speed to NC
SoupNazi - Who's glad he never asked where his reservoirs were
[Modified by Soup ****, 12:02 PM 8/30/2002]
you guys are cruel. Some noob is gonna read this thread and dump brake fluid on his pads.
Someone needs to add Asspenny's pic to a FAQ or something.
if it stays on when driving, and adding fluid doesnt solve it, you will more than likely need a new master cylinder reservoir cap (the thing you take off to add fluid
Brian
)Brian
whats we-todd-did?
Walk up to whomever is nearest to you at this moment and keep repeating the following words:
"I am sofa king we todd did"
It will become clear. Eventually
I AM SOFA KING WE TODD DID!
Drinker
