Ok to run 57.1mm rims on a 56.1mm hub?
Is it ok to run rims with a 57.1mm hub bore on my Integra that has a 56.1mm hub?
Would I need some type of hubcentric rings or is it plug and play for the rims? Thansks!
Depends on what kind of wheel you have. Some rims are hub centric and some are lug centric. Lug centric rims rely on the lug nuts to center them. Put the wheel on with aftermarket lug nuts (assuming they are aftermarket wheels) and check the distance around the hub and see if it's even. If not then look into hub centric rings.
The rims I'm getting are 15x6 BBS RA's offset +35 with a 57.1mm hub bore. Just want to make sure if I can slap these on the Integra before buying them... thanks for all the responses so far.
spaceman00
Apr 22, 2007 06:42 PM
X2BOARD
Suspension & Brakes
16
Jan 19, 2007 06:30 PM
