Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A2 Ecu wiring diagram
Old Oct 25, 2009 | 10:29 PM
wanna b R's Avatar
Default D17A2 Ecu wiring diagram
I was wondering if anyone have a 04 civic ex auto ecu wiring diagram? Thanks
Old Oct 26, 2009 | 09:16 PM
wanna b R's Avatar
Default Re: D17A2 Ecu wiring diagram
or just the o2 wiring on the ecu? what color and pin?
Old Oct 27, 2009 | 10:14 AM
supafil25's Avatar
2001-2003 Honda Civic ECU Wiring
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position VTEC ONLY
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Connector B (24 Pins)
2-yel-Fuel injector 4
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
6-grn-Radiator fan control
7-red/blk-A/T Pressure control solenoid valve A
8-red/wht-Engine Coolant sensor
9-blu/blk-VTEC Oil pressure switch VTEC ONLY
10-wht/blu-Alternator L Signal
13-wht/red-Alternator FR Signal
14-blu/red-EGR Valve VTEC ONLY
15-grn/yel-VTEC Solenoid valve
16-blk/red-A/T Pressure control solenoid valve B
17-red/yel-Intake air temp sensor
18-wht/grn-Alternator control
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins)– AUTO TRANSMISSION ONLY
1-wht/blk-A/T Pressure control solenoid valve A
2-yel/blu-Torque converter clutch solenoid
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
7-wht/red-Mainshaft speed sensor
8-brn/wht-A/T Pressure control solenoid valve B
9-red-Position switch D3
10-wht-position switch R
11-blu-position switch 2
12-blu/wht-position switch neutral or park
14-grn-countershaft speed sensor ground
15-blu-countershaft speed sensor
18-blu/yel-position switch D3 or D
20-yel-position switch D
21-wht/grn-mainshaft speed sensor ground
Connector E (31 pins)
1-grn/yel-Immobilizer fuel pump relay
2-wht/red-Secondary O2 Sensor EX Only
4-pnk-Sensor ground
5-yel/blu-Sensor voltage source
6-blk/wht-Secondary O2 sensor heater control EX Only
7-red/yel-PGM-FI main relay 1
9-yel/blk-Ignition input signal
12-blu/orn-Cruise control signal
13-wht/blu-Interlock control unit
14-lt grn-Fuel tank pressure sensor
15-grn/red-Electrical load detector
16-lt grn/blk-Power steering pressure switch
18-red-A/C Clutch
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
22-wht/blk-Brake pedal position switch
23-lt blu-K line
24-yel-Multiplex control unit comm line
26-blu-Engine speed pulse
27-red/blu-Immobilizer code
29-brn-Service check signal
30-red/wht-Write enable signal
31-grn/orn-MIL or check engine light enable
Old Oct 27, 2009 | 05:47 PM
DynastyRacer22's Avatar
this should be in the faq!
Old Oct 27, 2009 | 06:39 PM
wanna b R's Avatar
thanks!
Old Oct 27, 2009 | 09:40 PM
supafil25's Avatar
no prob guys
Old Jun 19, 2010 | 05:59 PM
jcwh's Avatar
secondary o2 sensor??? is the ex in this diagram vtec or non? please help
Old Aug 16, 2012 | 09:19 PM
78si's Avatar
Im looking for a connector view pinout..
Old Oct 13, 2012 | 10:56 AM
jcar's Avatar
which is the rps indicator pin???
Old Apr 14, 2013 | 02:16 PM
josepina's Avatar
i have the same problem i need the diagram for a 02 civic vtec secondary o2 sensor
Old Jun 29, 2017 | 10:18 AM
Dante365's Avatar
What is the voltage that the EGR must have to be powered? The red blue wire is the one that carries the voltage of the computer, but only gives 6 volts Should carry 12 volts?, in that case it is not the damaged EGR. If not that the computer does not send enough voltage, I do not understand someone help please. Honda Civic Ex 2002 A17a2
MUGENVX9
Sep 13, 2013 04:27 PM
seanyreeves
Engine Management and Tuning
Oct 12, 2011 10:15 PM
GsrIntegra789
Feb 9, 2009 06:01 PM
R883
Jul 21, 2008 11:52 AM
geoscranny84
Apr 10, 2006 11:48 AM
