Gsr smoking bad (white smoke) & other issues
Old Oct 25, 2009 | 05:49 PM
jorge59la's Avatar
Default Gsr smoking bad (white smoke) & other issues
99' Gsr with bolt ons.
So car is smoking really bad.
I have oil coming out of my muffler. I also have oil coming out of my distributor cap.
My car was turbo'd before and it didnt smoke at all. Took turbo off, re-tuned and it began smoking.
Also, I have no o2 sensor (front). Is this a problem? I believe it was blocked off from ecu during tuning since i didnt have it at the time. When vtec is engaged my car goes into (limp) it idles really low and runs sluggish when come to a complete stop it idles fine and runs fine until vtec engages again. Could this be my ecu?
I will shop around to get a leak down and comp test's. Cylinder 3 spark plug is oily, the rest of them are fine. I am also loosing oil. Checked radiator and i have no bubbles.
tnx!
Old Oct 25, 2009 | 05:54 PM
Rajin's Avatar
Default Re: Gsr smoking bad (white smoke) & other issues
Check the gaskets.
White smoke....the tune may be wrong good sir. You need to check it.
Old Oct 25, 2009 | 08:12 PM
Bluesiff's Avatar
Head gasket brother.
Old Oct 26, 2009 | 03:29 PM
kulo's Avatar
blue smoke or rings right?
Old Oct 26, 2009 | 04:18 PM
DDTECH's Avatar
Blue smoke is oil
White smoke is coolent
Probably a leak around the headgasket on cyls 1 or 4.. where the waterjacket is.
Old Oct 28, 2009 | 04:53 PM
jorge59la's Avatar
would i have oil coming out of my muffler if it's the headgasket?
what may cause oil to come out of my distributor cap?
Old Oct 29, 2009 | 03:57 PM
jorge59la's Avatar
Old Oct 29, 2009 | 05:20 PM
Sam-DB8's Avatar
No bubbles/oil in the coolant doesn't make it sound like a head gasket issue. I assume you've already checked the old oil feed/return lines to the turbo? They might be causing oil to end up in odd places/loose oil if they weren't properly plugged when the turbo was removed.
Old Oct 29, 2009 | 06:01 PM
vzqz18's Avatar
i would go with this post.
Old Oct 29, 2009 | 06:19 PM
sabrosa489's Avatar
papi the oil in the distributor and on the spark plug could just a bad seal on the valve cover gasket. try to get a leak down test for your engine, it usually help to pin point or eliminated on necessary work that you may not need.
Old Oct 29, 2009 | 08:38 PM
jorge59la's Avatar
well the feed line was eliminated and the hole from the head was plugged. The return line is still connected to the oil pan, I just folded the rubber hose and ziptied it! (problem>?)
I have no idea were to get leak down test, I have called around and when i ask they seem lost.
Old Oct 30, 2009 | 06:56 PM
blackpearlgsr29's Avatar
sounds like somethin im goin thru but a little different! ***** drivin me wild. i got a 98 gsr motor in a ek coupe. put a skunk2 mani and typeR throttle body on it with a stock exhaust back on for that sleeper. i juss put typeR cams in it with a new oem head gasket and timing belt and also got the valves adjusted and the head tested! ran good as hell for 3 weeks or so then started runin sluggish as hell and smokin blue a little at high rpms and the pcv valve keeps gettin packed with oil and it looked like a little got in the intake manifold cleaned it out as well as the pcv and it seemed to run fine again for a couple weeks then same thing! 2day checked the compression from left to right it was 220, in about 175 180 in the rest! the cylinder that had 220 the valve cover grommet leaks oil down to the plug but doesnt make it miss fire.. what do yall think is goin on bad valve adjustment, timing, intake mani gasket?? or what love the car but this problem is killin me thanks
Old Oct 31, 2009 | 03:36 AM
VIDC2's Avatar
HEAD GASKET!!!
Old Nov 1, 2009 | 05:49 PM
jorge59la's Avatar
so i will do the headgasket. If i wanted to do rings also what parts would i need? just rings?
so far:
headgasket
piston rings
arp studs
valvecover gasket
Old Nov 2, 2009 | 05:56 PM
jorge59la's Avatar
bp
Old Sep 26, 2010 | 03:38 AM
unknownally's Avatar
Happiest92Ricer
13
Apr 30, 2013 06:43 PM
jdmek2277
10
Dec 13, 2007 10:54 AM
djstain
Jun 1, 2006 09:58 PM
4drITR
May 3, 2006 09:13 PM
1990civicsi
Aug 8, 2004 06:33 PM
