03 rsx s action clutch install, problems shifting and whining
Old Oct 24, 2009 | 02:47 PM
Metalluthier's Avatar
Default 03 rsx s action clutch install, problems shifting and whining
So I got my action clutch installed, stage 4. After the installation when clutch begins to engage, there is a distinct chirping/whining coming from the transmission. My gears no longer ease into place anymore, now they just feel hard and notchy when shifting, actually have to apply good pressure to get it into gear. I did also install poly inserts for my front and rear mounts as they were beginning to tear. Any ideas?
Old Oct 25, 2009 | 12:28 AM
Default Re: 03 rsx s action clutch install, problems shifting and whining
Anything?
Old Oct 25, 2009 | 07:25 AM
WhiteOnRice's Avatar
Rule out the motor inserts. My mounts did nothing but make shifting easier and more solid and precise.
Did you do the install? If not, take the car back to the shop that did.
Old Oct 25, 2009 | 01:37 PM
Yea I installed it myself, the second clutch I've installed in my car. I've had hasport mounts before so I didn't really think that had anything to do with anything,but I fugured the mount inserts may be contributing to the noise. Plus my car shakes like mad when under 1000 rpm now.
Old Oct 25, 2009 | 02:54 PM
hawaiiancb74's Avatar
which clutch did u get? 2 ms? sprung or unsprung? Kevlar? 6 puck? with a heavy duty clutch there is ease any more its clutch on clutch off, feather is just about non apparent. how much tranny fluid did u put back in it? and most puck clutches will make some noise during engagement.
Old Oct 25, 2009 | 05:56 PM
It's a 1ms 6 puck non grooved sprung non Kevlar. I never drained the trans and never filled it. I usually would drain it, but didn't this time. The guys i had help me refused to help if I was going to spend the time to drain it, number and label bolts, etc. Apparently that makes me a *****? Anyway, there you go. Thinking Bout having AAMCO take a look at iron Tursday bc I'm tired of taking this **** apart. If you own an RSX you know the sub frame is just a massive annoyance
Old Oct 25, 2009 | 05:59 PM
Oh and I went from an Exedy stage 2 thick 3 puck to this Action 1MS
Old Oct 25, 2009 | 09:32 PM
umm dude u have to drain the trans to pull the axles, the fill plug is higher than the axle imputs. the people that helped you are ****ing retarded and they might have just cost you grand in repairs.
Old Oct 26, 2009 | 01:16 PM
That isn't true.
His fluid level is probably perfectly fine.
Old Oct 26, 2009 | 03:27 PM
hmm i coulda swore it is when it was installed, none the less u should no mater what.
Old Oct 26, 2009 | 04:19 PM
kPRO dz's Avatar
i was told that clutch chatter was common in twin disk clutches..do you think its the same symptom?
Old Oct 26, 2009 | 05:41 PM
its not a twin, but the noise is still common
Old Nov 7, 2009 | 06:55 AM
It's just a terrible noise. Sounds like a dying elephant... Not really a whine, more between a low pitched chirping or two different compounds causing uneven friction. Like if I tried to erase a chalkboard with rubber or poly. I can go in reverse without touching the throttle, just gotta lift up the clutch a little... I could hear my gears the other day, sounds terrible. Only shifts and drives alright when it's heated up. IDK Acura trans are terrible...
Old Nov 7, 2009 | 07:31 AM
idk about that. but i hve the same 1ms clutch and i get the same noise on engagement
Old Nov 18, 2009 | 07:01 PM
Hmm, anymore suggestions? Could it be the starter?
Old Nov 18, 2009 | 10:21 PM
its fine..
Old Nov 19, 2009 | 02:31 AM
sicky's Avatar
grammer nawzi
Random question: why on earth are you running that kind of clutch is this is a DD? I mean, are you putting down over 400whp? If not, seems like a waste of money.
Old Nov 19, 2009 | 08:51 PM
a 1 ms isnt for 400whp more like 250
Old Dec 28, 2009 | 11:54 AM
Just to let you guys know, my trans complete failed on me. The grinding got worse, transmission began leaking after I ran Royal Purple through it, and now I'm just having trouble trying to find someone who knows what the **** they're doing here in Eugene, OR and can work on my trans besides the dealership. Anyone know a good transmission specialist around here? All I can find are Automatic specialists, who fix soccer mom vans and classic auto overdrives...
GAHHJSBKDFJSNFJLJDSFLKJDSFNOPISJG:LISMD
Old Dec 28, 2009 | 01:17 PM
josh's ep3's Avatar
Function > Form
Might be worth it to just scrap the tranny. Sell it for what someone is willing to pay for it, and get a new one dude. I would just start keeping my eye on craigslist or at other online retailers for a new tranny.
Old Dec 28, 2009 | 04:20 PM
cscdc5's Avatar
best guess for me is that the clutch and pressure plate aren't flush that would cause a hard pedal....another could be the syncros in the transmission are starting to wear
Old Dec 31, 2009 | 02:02 PM
Yea, well, I took it to the Honda dealership, so of course they are telling me my clutch is trash, I just installed it, then they're telling me my flywheel needs to be scrapped (installed in Feb 09' Exedy Lightweight) and they want to charge me $2000 for the install and parts, ****in' really? They found a refurbished trans for $2600. So its up to $4600 and they won't let me get my car back without them replacing parts I don't want replaced.
Shoulda just ordered a trans through them and done it myself for $2600, hah
davefootball123
Honda Civic (2006 - 2015)
Mar 5, 2018 02:28 PM
eromezab
Transmission & Drivetrain
Apr 26, 2014 08:57 PM
collin-eg2
Mar 30, 2012 12:26 AM
jsrusse11
14
Nov 7, 2005 10:55 AM
Lauj87
Aug 27, 2005 09:59 PM
