B18C ITR Compression Noises
Old Oct 24, 2009 | 02:31 PM
EJ8_Man's Avatar
Default B18C ITR Compression Noises
So this is my first motor build and I wanted to run it past someone who is experienced (you guys). Does anyone know if this sounds normal? This is me spinning my B18C ITR motor.
Round 1
http://www.youtube.com/watch?v=5zEGqWLLIQY
Round 2 slower
http://www.youtube.com/watch?v=_UyGXbVDytg
Thanks
Old Oct 27, 2009 | 05:29 PM
EJ8_Man's Avatar
Default Re: B18C ITR Compression Noises
74 Views and no replies
Hopefully this means nothing is standing out as being f.u.b.a.r. It sounds okay to me, but I was concerned about some of the hissing noises that sounded like air coming back into the crank case. The cylinder walls looked shiney clean, no scoring or scrapes from bad rings. The valves were vacuumed checked and everything was okay. New head gasket, ARP head studs, and a long list of OEM parts I will spare you all from having to read
I hand cranked the compression up to 120 psi across all cylinders. But cold compression checks are virtually worthless. I noticed it all depends on how hard you crank. If I go slow I get virtually no compression, like 50 psi
Old Oct 27, 2009 | 05:41 PM
Dogginator's Avatar
Daisy... Daisy...
They all make sucking noises at low speed rotation.
Old Oct 28, 2009 | 09:09 AM
EJ8_Man's Avatar
Thank you. I needed reassurance lol
Old Oct 28, 2009 | 09:32 AM
ironcheftony's Avatar
well that noise is compression, and it just seeping out while u open the valves(spining the motor)
its because u have spark plugs in there so its making compression, it u take out the spark plugs it will be easier to turn and u will not hear that n e more
Old Oct 28, 2009 | 01:47 PM
EJ8_Man's Avatar
I left the plugs in so I could check the compression Thanks for your input though. There is a running bet that my motor will go as soon as I turn the key after I drop it. It's my first build
JDMCRX
May 20, 2019 07:29 PM
oXeNo
12
Aug 16, 2011 04:44 PM
unknow
Sep 14, 2010 05:49 AM
94typeR
May 7, 2007 04:32 PM
