Heater problem... kinda weird...pic's
Old Oct 24, 2009 | 02:09 PM
KLUE's Avatar
Default Heater problem... kinda weird...pic's
Ok heres the deal, kinda long so i'll leave cliffs at the bottom if you want to read those.
My car is a 94 LS with a GSR swap. So the radiator in my car took a crap on me so I figured i'd change the radiator and thermostat at the same time (the heater is working at this time). When I went to change them I noticed the hose that goes from the head to the heater had a small hole in it near where it connects to the head (pic at bottom). So I snipped about a inch off of it and put it back on, didn't stretch or anything.
I then put the thermostat in, radiator and put new coolant in it. Started it and realized the gasket for the thermostat didn't stay where it was supposed too and I closed the thermostat housing on it. Took the thermostat off again, got a new gasket and put everything together again.
Turned the car on filled the radiator with coolant again, turned the heater on full blast and got jack ****, the air is luke warm at best.
The thermostat is a honda oem replacement. Theres no leaks, the system is full of coolant, and now I have no heat. Keep in mind before I took the hose off the heater was hot enough to cook a egg, so I know its not the heater core. The car warms up correctly and dosen't stay cold or hot, it runs perfect really.
The only thing I can think of is drain all the liquids again, flush it and start again?
Anyone have this happen? ANY help or ideas are greatly apprciated... Thank you
cliffs:
radiator takes a crap
changed radiator, hose, thermostat
no heat
Old Oct 24, 2009 | 03:44 PM
eaglewesman's Avatar
Default Re: Heater problem... kinda weird...pic's
interesting problem... i'd like to hear the answer. sorry i can't help you on this one
Old Oct 24, 2009 | 06:45 PM
Stasher1's Avatar
check the silver wire that resembles that of a clothes hanger
it's on the top of the housing where the hose goes into the firewall
that wire runs from there to the climate control
if anything is loose or out of place (this can happen), then your climate control is useless
Old Oct 24, 2009 | 06:59 PM
Tegraracer90's Avatar
ur heater core is air locked....when the car is cool...open the radiator cap and let the car run and warm up...air should make its way through the system....u can help it alittle bit by occasionally squeezing the upper radiator hose a bit
Old Oct 24, 2009 | 07:52 PM
KLUE's Avatar
Thanks for the info! Gonna try and get the air out tomorrow! Will post results! Thanks!
Old Oct 26, 2009 | 01:54 PM
KLUE's Avatar
Ok. Bled the system twice. Took the cap off, turned the car on pinched hoses and let it run for about 20 minutes. Added coolant as needed. Drove down the highway and got nothing, everything has stayed exactly the same... Any more ideas?
Old Oct 26, 2009 | 02:16 PM
SleeperGSR's Avatar
what does your temp gage indicate?
Old Oct 26, 2009 | 02:29 PM
KILLAB17VTEC's Avatar
Genetically Gay
thats weird!is your car blowin cold air?i had this kinda problem before.i replace my heater blower then my car was still blowin cold air...i figureout that it was the connecter that open up the heatercore was not plug.i replug it now i'm gettin hot heat and did'nt bleed nothin.u might wanna double check..gl
Old Oct 26, 2009 | 02:57 PM
Rajin's Avatar
Something is amiss in your wiring, I'm having this exact issue in my DA.
Old Oct 26, 2009 | 03:12 PM
KLUE's Avatar
it stays exactly where it's supposed to be, it warms up perfectly and does not even touch the half-way mark. It dosen't under heat either.. esentially it runs perfect.
your talking about the wire that goes from the climate control to the heater core.. and the wire that goes to the coolant hose corect? If you are they've been checked, and are functioning,,,
interesting, maybe i need to check out my engine harness or something?
Old Oct 26, 2009 | 03:13 PM
Rajin's Avatar
No, dash harness man.
It'd be in that area. Short in the wiring and such.
Old Oct 26, 2009 | 03:24 PM
KLUE's Avatar
checked all my fuses again they're good... I really dont want to take the dash apart lol... but i guess i'll have to
DTvn
Mar 30, 2015 07:54 PM
1991crx16
14
Jan 26, 2011 01:47 PM
new_climber
Dec 14, 2008 10:07 PM
master honda tech
Sep 7, 2004 12:34 PM
hatchback
Apr 21, 2003 01:14 AM
